1948 F1 Flathead Six 226 Oil Pump
As a practical matter, the best approach if there is a perceived problem with the pump is to remove it and inspect the clearances per the workshop manual.
If you have verified low oil pressure (with a known good mechanical gauge), first thing I would check is the relief valve. They can get gummed up and stick open. They are relatively simple to remove with the engine in place. The springs also get weak. Specs for the spring are also in the manual.
Checking the inlet screen and pan for excess sludge is a good step also.
You might want to read "Brain75"s thread on his oil pressure problems, also his thread on putting a T5 on his 226:
https://www.ford-trucks.com/forums/1...226-stock.html
https://www.ford-trucks.com/forums/1...-progress.html
(there is a table in that thread that's messed up, unfortunately)
His crankshaft and rods were shot, the journals were oval. He'd plastigage'd the journals and happened to catch them at a tight spot, so he thought they were OK. When he yanked the engine and miked them, they had huge clearance in some spots. He ended up buying a good used engine.
The 49-51 Workshop Manual includes the 226; available electronically and hard copy on eBay. The Parts CD is also very useful, 1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage.
4601ton
12-31-2011 06:09 PM
shortblock2000
12-12-2006 05:17 AM
neil_singleton
07-22-2006 08:14 AM
studlybilly
01-24-2005 10:31 PM
