Oil Pump
Old Apr 4, 2008 | 05:20 AM
akissz's Avatar
akissz
Oil Pump
If my oil pressure is low is there anything else it could be besides the gage or the oil pump?
Old Apr 4, 2008 | 07:15 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Main bearings...
Old Apr 4, 2008 | 08:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Not having any idea what your pressure is hot/cold, what engine you have, what oil, what filter system, what gauge, etc, I would venture to say there is almost no chance it is just the oil pump or the gauge.
Old Apr 4, 2008 | 09:11 AM
akissz's Avatar
akissz
I'm not sure what that means.
akissz's Avatar
akissz
Originally Posted by GreatNorthWoods
Main bearings...
What are the main bearings?
Old Apr 4, 2008 | 09:16 AM
Bdox's Avatar
Bdox
Those would be your crankshaft bearings. (Tired old motor syndrome.) Sounds like you need to get some help from someone knowlegeable about motors. You will need to drop the pan to check the bearings and the pickup screeen.
Old Apr 4, 2008 | 09:24 AM
akissz's Avatar
akissz
Some guys are working on it this weekend. What's the difference between a good bearing and a bad bearing visually?
Old Apr 4, 2008 | 09:39 AM
akissz's Avatar
akissz
Is anyone here near Dallas Texas?
Old Apr 4, 2008 | 09:44 AM
Bdox's Avatar
Bdox
There is only a few thousandths of an inch difference. Worn bearings will usually "look" worn on the side that comes in contact with the crankshaft. Also, worn bearings may show some grooves or may appear to have a copper color to them. These are signs of excessive wear and that explains your "low oil pressure" and/or knocking sound in the motor.
Go to a parts store and buy a product called "Plasti-gague." You will also need a torque wrench. Follow the directions carefully.
If there are grooves or roughness in the surfaces of the crank where it contacts the bearings, (even just one!) then the engine will have to be overhauled or replaced.
Old Apr 4, 2008 | 09:55 AM
akissz's Avatar
akissz
My truck was supposed to of had only about 8000 miles on it when I first got it and the rubber pads on the break and gas and clutch were not warn so I was told once that if the rubber is not warn that it could possibly be accurate millage. Since I got the truck I've went about 4500 miles. If this were the case and it is a relatively new unused motor but OLD: what would be causing the low oil pressure?
Old Apr 4, 2008 | 10:54 AM
Bdox's Avatar
Bdox
If it is not caused by high milage, it could be due to running low on oil, overheating or abuse. Oil contamination could also be a cause.
There is an off chance that your oil pickup screen is clogged from sludge, which can cause low oil pressure.
You don't state what motor you have in your truck or it's age.
Old Apr 4, 2008 | 11:37 AM
akissz's Avatar
akissz
1953, p350, 6cil?
Old Apr 4, 2008 | 01:17 PM
Bdox's Avatar
Bdox
You might have been deceived about the mileage on you 1953 truck being only 8,000.
On the other hand, if it is as described, it may have sat for thirty years or more without an oil change. If so, the oil was likely to be contaminated with acids and water from sitting so long.
Old Apr 4, 2008 | 01:23 PM
akissz's Avatar
akissz
but it runs so well.... it runs better than lots of new vehicles; especially during the winter. i just worry about the gages and the oil leaking...
Old Apr 4, 2008 | 02:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Oil leaking or oil pressure? Two completely separate things. Maybe you should take it to a garage and have them work on it.
