Non-Ford Engine Question
Old Oct 28, 2016 | 12:07 PM
  #31
firegod33's Avatar
firegod33
The Jeep fuel system is also designed for a return to the tank, from the fuel filter. If the proper filter is not being used, it can cause running issues.
Old Oct 28, 2016 | 03:01 PM
  #32
quinletc's Avatar
quinletc
Originally Posted by MojaveMuse
did you check both your pumps and filters? almost sounds like the engine gets starved, maybe too much vacuum builds up after a while in the system moving the chunk of what-have-you to block. engine runs for a bit until it runs out of food. won't start up immediately because that pressure is still there, then after a bit lets off, the chunk settles back down. just my thoughts. It's also possible i'm dead wrong.
It's getting fuel.
Old Oct 30, 2016 | 11:51 PM
  #33
quinletc's Avatar
quinletc
Well, we scrapped the old distributor, coil, and control module. We also replaced the valve cover gasket. As you can see and hear below, the new HEI unit from CRT Performance works like a champ.
An older problem has resurfaced, though.
With the clutch pedal fully depressed, the clutch does not fully disengage. The first time this happened, we discovered that the lower clutch push rod was bad. Replacing it seemed to cure the problem. Now, it's back again. Was too late when we got home to look in there and see what's going on, but I hope the problem is as obvious as it was the last time.
Old Oct 31, 2016 | 10:10 AM
  #34
firegod33's Avatar
firegod33
The clutch bell crank is famous for wearing out the holes at the pivot points. I replaced all of my clutch linkage, last year. Check Morris 4x4 for replacement parts. Alternatively, you could weld the worn parts and grind them smooth, to repair what you have. There are also plastic bushings in the bell crank that wear out and need replacement.
That's a nice, clean engine bay. Engine sounds good!
aic
Apr 6, 2020 12:32 PM
73FordF100
25
Jun 12, 2011 11:51 AM
LimeyRich
Electrical Systems/Wiring
Apr 28, 2011 08:52 AM
Holiver31
Mar 9, 2011 07:10 AM
