Front Spring Leveling Kit
Old Oct 15, 2016 | 01:48 PM
Dfreeman2009's Avatar
Dfreeman2009
I plan on getting a leveling kit for my 2002 7.3 F250, any recommended kits? And is there any other parts that would need to be replaced or reworked that the kit doesn't provide? (brake lines, sway bar links?)
Thanks,
Dan
Old Oct 17, 2016 | 08:16 AM
F250_'s Avatar
F250_
You need to consider extending the length of your front shocks top mounting bolt by whatever the same length as the height of the leveling kit (i.e. 1.5", 2". 2.5", etc.). Otherwise, you'll max out their extension over serious bumps, and both your ride quality and shock life will be compromised.
Old Oct 18, 2016 | 02:37 PM
87beater's Avatar
87beater
You will most likely need to install an adjustable trac bar to compensate for the increased height. Otherwise, your axle will be pulled off center.
Old Oct 21, 2016 | 05:45 PM
Dfreeman2009
Just purchased and installed new skyjacker shocks, unfortunately they are for 0"-2" so maybe I'll hold of for a bit until I get some use out of them
thanks
lasallen
Apr 16, 2018 01:24 PM
Psyclopse
Oct 1, 2012 10:36 PM
onuredneck707
Feb 27, 2011 08:37 PM
HarleyFXDL
Mar 2, 2009 11:21 PM
MRBASS
Feb 1, 2004 08:40 PM
