Sponsored by: Real Truck
Bilstein 2" leveling kit
Old Mar 2, 2009 | 07:06 PM
HarleyFXDL's Avatar
HarleyFXDL
Has anyone installed a Bilstein 2" leveling kit? Good kit? How did the truck sit? How was the install? I hate the way my truck sits. I had a set of Bilsteins on my other truck and I loved them.
Old Mar 2, 2009 | 07:19 PM
melon350's Avatar
melon350
I just put one on mine last week. The shocks ride great, install was very easy. I was on a truck lift though so that helped, doing it in the driveway probably wouldn't be so fun. It only took about 20 minutes, all I had to undo were the shocks, sway links, and the brake line bracket. You will need some caster bushings when you are done, mine dropped to around .5 degrees. I wish it would have gone up a bit more, it cut the difference on my truck in half, but I suppose if it went up much more I would be wanting a trac bar which would add to the cost.
Old Mar 2, 2009 | 11:21 PM
DCSpecial's Avatar
DCSpecial
The Bilstein 2.25" is a good setup. Progressive rate coils, shocks valved specifically for the SD, etc.
The one thing I would add to the setup is caster cams, like what Icon includes in there 2.5" setup.
Also, an adjustable trac bar is a nice upgrade to keep the axle centered under the truck.
my996duc1
6.7L Power Stroke Diesel
Jun 2, 2015 02:01 PM
fx4king2011
Offroad & 4x4
Oct 27, 2014 03:11 PM
2zwudz
Jun 21, 2014 04:56 PM
F250_
18
Nov 4, 2013 04:04 PM
rcklnhunter
35
May 20, 2011 04:53 PM
