Cracking injector lines
Old Oct 14, 2016 | 06:33 PM
Angelo190471's Avatar
Angelo190471
My 92 just cracked anouther injector line. This id the second one that the nut on the ip cracked while i was driving it. What is causing them to crack they are expensive
Thanks angelo
Old Oct 14, 2016 | 07:39 PM
tecgod13's Avatar
tecgod13
There should be metal clamps with rubber isolators holding the lines together. They help dampen the vibrations on the lines. If the clamps are missing, the vibrations cause the lines to crack.
Old Oct 14, 2016 | 10:38 PM
Angelo190471
You have a picture or part number?
Old Oct 15, 2016 | 06:31 AM
fuzzy1626's Avatar
fuzzy1626
Injector line clamp (4 line assy) For 1983 - 1994 7.3L IDI & 6.9L Ford Diesel
Old Oct 15, 2016 | 06:53 AM
Angelo190471
Yeah my truck doesnt have those. do i just need two?
Old Oct 15, 2016 | 10:10 AM
Fixnstuff's Avatar
Fixnstuff
You will need 4. 2 on each side.
You may see marks where the original clamps were installed.
I've seen 2 different configurations in photos and yet another different configuration in a drawing.
Scroll down to the 3rd photo in the link below to see one configuration. This is how mine are installed on my 1987 6.9L and I'm sure it is original. Notice that each clamp is only holding 3 lines:
https://www.ford-trucks.com/forums/9...ml#post8895461
Here is a posted photo from a different topic thread showing the front clamp on the driver's side holding all 4 lines instead of 3:
https://www.ford-trucks.com/forums/7...ml#post6124598
Finally here is a drawing from 'US Diesel Parts' in a listing for a new #4 fuel line that shows the front driver's side clamp holding 4 lines and the rear driver's side clamp holding only 2 lines. (It also states that the clamps are discontinued and not available):
#4 High Pressure Fuel Injection Line Ford 6.9L 7.3L
You'll have to examine your lines to see where the clamps should go. If the lines look like the first photo showing each of the 4 (grey) clamps holding 3 lines, DO NOT try to bend the number 8 line (driver's side closest to the intake) in order to get a clamp over all 4 lines. That would put too much stress on that line and the connection fittings. Just install it over the 3 lines as shown.
If your lines look like the ones painted Red in the second photo then you should install the clamp that way. It could be that someone bent that line to fit like that but I certainly would not recommend bending one to fit and the first method shown, each clamp holding 3 lines is very adequate.
As far as the drawing, I haven't seen vibration dampener clamps installed that way in any online photos, (with the rear clamp on driver's side holding only 2 lines). If the front clamp is holding 4 lines (as shown) then that configuration would also be very adequate.
Until today I've always thought that the clamps were the same for all of the IDIs 83-94. Possibly different in the E Series Vans or the Bronco.
SgtOtaku
18
Sep 27, 2020 08:27 PM
1lowscort
Apr 12, 2011 09:19 PM
ttexastim
24
Nov 17, 2010 03:38 PM
mabc926
May 7, 2010 10:15 AM
BlueOvalBud
Mar 27, 2010 04:00 PM
