Injector line routing
Old May 4, 2008 | 08:23 PM
rmalottwtes30's Avatar
rmalottwtes30
Well I guess when the PO changed the GP's on my rig he didn't put or adjust the injector lines right. We noticed that the injector line hits up against the throttle pedel bracket, and therefore the PO bent the bracket, which apparently is what is causing my truck not to get full throttle(See Thread) We caught this when we was replacing my throttle cable thinking that was the problem but apparently not! So anyone have a diagram or a good picture to show how to route these properly? Also they appear to be original should I replace?
Old May 4, 2008 | 09:42 PM
6.9 Diesel's Avatar
6.9 Diesel
well ive never had this problem, everytime ive had my lines off my truck, theyve gone back one way and one way only and that is the way they came off. did you or the person who reinstalled them bend them to fit back? never ran into this problem but thats the only way i can see it happening, unless a couple lines were put on backwards but other than that if your lines are semi clean, and arent rotten nor leaking i would not worry about replacing them, i have over 178000 miles on my lines and they look and function just fine, check them over. These lines do put up with an extreme amount of pressure so it wont hurt to check them, for piece of mind, as for a routing diagram, ill take some pictures of mine and hopefully this will aid in correcting your problem, not getting full pedal does suck (not that these engines have 1000 horses anyway) but ill try to help in any way i can.
Old May 5, 2008 | 03:53 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
What does PO stand for?
Old May 5, 2008 | 03:58 PM
rmalottwtes30
Previous Owner
Old May 5, 2008 | 05:05 PM
FORD MEGA CAB!!!
You might try loosinging some of the lines and move them a little. They wont move much, but You might just get it to move enough to get some clearence. Loosen the line on the pump and the injector and it will probably move.
Good luck
Old May 6, 2008 | 02:21 PM
newr's Avatar
newr
More than one
Might be worth looking through the lines, slow and carefull. If the PO bent one to fit it's a good bet that there was at least one other. If the bend causes any restriction in flow it would probably be a good idea to correct it.
FWIW
Old May 6, 2008 | 05:47 PM
LilDuke's Avatar
LilDuke
Your missing the line clamp.
Old May 6, 2008 | 08:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Just happen to have what you are looking for.
Old May 6, 2008 | 09:16 PM
rmalottwtes30
SWEET Thanks for the pictures Dave, and Dave...LOL
Well apparently my truck dont have any of the clamps for the injector lines. Anyone know where I could buy them at?
Old May 6, 2008 | 10:48 PM
Dave Sponaugle
Diesel performance parts and accessories. Diesel injectors, pumps, filters, kits, additive, gauges and apparel. (MWFI) is kinda close to you and about as good as you will get for prices.
You need one two line clamp, two three line clamps and one four line clamp.
2.50+2.78+2.78+3.92 = 11.98
Old May 7, 2008 | 03:05 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Originally Posted by rmalottwtes30
Previous Owner
NO! It's Probation Officer, don't you watch TV? LOL
Old May 7, 2008 | 03:08 AM
Dodge/Cummins
Dave,
Do you have any kids/grandkids and if you do...do you have more pictures of them or your 6.9L? LOL
Seriously though you must have planned ahead to have all of these pictures to use to answer questions with! A pictures worth a thousand words.
Old May 7, 2008 | 05:05 AM
FORD MEGA CAB!!!
OH , That motor has a better paint job than both my trucks and sidekick. Forgot to paint the Alternator though, and the 3 intake bolts on the back...Looks great. I saved that picture on my computer for later referral if I need it.
Originally Posted by Dodge/Cummins
NO, It's Probation Officer, don't you watch TV?
Hey, He might be like me and don't own one!!!
Old May 7, 2008 | 03:16 PM
Dodge/Cummins
It has a better paint job than anything I own I think.
Old May 7, 2008 | 10:54 PM
Dave Sponaugle
I found that on the internet, ugly motor, but great for injection line questions.
I save pictures I find that save me typing very long descriptions that don't really get the answer across clearly.
And I have more pictures of my truck than I do of my son, my wife has all of those.
Nice looking motor.
Built it with my very own hands, my son helped so he could learn how to tear down and reassemble a motor.
That turned out to be a good deal for me, because he got to see and learn how to set and measure clearances, about torque patterns and steps, engine machining, balancing, tolerances and all those other mechanic tricks.
And he really got a kick out of learning some of my diesel hot rod tricks.
16 year old boy learning how to hot rod something, that was cool.
Nice father son experience, we had a lot of fun.
During the tear down however, mom was not so happy.
We all know how black diesel oil is.....LMAO thinking about it to this day.
And now at 18, he wants to build one for himself.
I can forsee another build in the near future.
