Changing a injector line
Old Apr 11, 2011 | 08:19 PM
1lowscort's Avatar
1lowscort
I have to replace the #7 injector line (furthest back on the pass side). Unfortunately, and naturally, this is also the most difficult one to get to on the IP. So, can this be changed without pulling the IP?
Old Apr 11, 2011 | 08:59 PM
Sycostang67's Avatar
Sycostang67
You may be able to get it with a crows foot or bending a wrench. It would also just be easier to remove the other lines that are in the way instead of the IP.
Old Apr 11, 2011 | 09:19 PM
BlueOvalBud's Avatar
BlueOvalBud
Yeah, I've had to replace that stinkin' line before also. I just removed the lines that were in the way.
Old Apr 11, 2011 | 09:20 PM
snaponprofile's Avatar
snaponprofile
X2, just remove the lines in the way and you should be able to get to it. After I did the ip install, one of the bottom lines were leaking, so i just removed the lines in the way and was able to tighten it.
Old Apr 12, 2011 | 09:32 AM
1lowscort's Avatar
1lowscort
Awesome, thanks folks! I'll probably work on that today.
Old Apr 12, 2011 | 01:47 PM
snaponprofile
Here is a place to get them.
Link from blue.
6.9 Ford Diesel parts Fuel Injection Turbocharger
Old Apr 12, 2011 | 02:18 PM
BlueOvalBud
Yep, I've got one of their fancy shiny steel lines on my engine.
Old Apr 12, 2011 | 09:19 PM
1lowscort's Avatar
1lowscort
Line swapped! Not nearly as bad as I was expecting. Thanks for the help, all!
119er
Jul 18, 2013 07:29 PM
ola1234
Nov 2, 2011 05:56 AM
540milotalon
Aug 4, 2011 11:57 PM
TurtleRacing
19
Dec 27, 2007 11:42 AM
bignorth
Dec 7, 2006 11:34 PM
