460 carb replacement
Old Oct 13, 2016 | 11:19 AM
Plowboy34's Avatar
Plowboy34
if you are just putting around a vacuum secondary 4bbl will not open so basically you would be running a 2bbl, but just in case you do ever have to use it then it would be there. May actually be cheaper in the long run too if you have to buy adapters to get to a 2bbl rather than just getting a 4bbl up front. Just a thought.
Old Oct 13, 2016 | 11:28 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
About the only thing that's going to "wear out" is the plastic throttle linkage bushings.
If it's still the stock 4180 a 3-1346 rebuild kit is around $50, and everything goes right back as it is.
ilbiker
13
Sep 15, 2013 10:54 PM
HowardN
Feb 17, 2007 11:52 PM
phyxius
Oct 5, 2006 06:03 PM
uncle jessie
Apr 23, 2005 01:04 PM
flathead
Mar 7, 2005 05:46 PM
