460 carbs
Old Mar 6, 2005 | 09:07 AM
flathead's Avatar
flathead
460 carbs
I'm putting a 460 in a Ford truck and have several carburetor options. The present carb and intake I have is the spread bore Motorcraft. I have heard some bad things about these carbs so I am considering several options. Holley square bore 4 barrels, such as a stock '85 Ford-Holley 4180, a Holley 4160 off a '70 Chrysler 440 (list 4366) or maybe a Holley 3310. All these Holleys are square bore carbs and I realize that I will have to find a square bore intake maniford to use them. Thanks.
Old Mar 6, 2005 | 01:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
You can buy square to spread bore adapters. Any carb in the 700-800 CFM range will work.
Old Mar 6, 2005 | 09:56 PM
LxMan1's Avatar
LxMan1
The 3310 should work pretty good.
Better than your other choices listed.
Old Mar 7, 2005 | 05:46 PM
frty7ford's Avatar
frty7ford
Summit has an addapter for this application. It works great. I had to call as it was not listed in the catalog. It replaces the egr spacer.
Jay94250
13
Jul 31, 2024 06:55 AM
jonny.redneck
Apr 23, 2014 04:43 PM
lance65
Sep 3, 2013 07:41 AM
84espy
Sep 19, 2012 04:13 PM
buckrogers
Sep 6, 2007 05:09 PM
