460 carb replacement
Old Oct 11, 2016 | 11:44 PM
Red454sedgwick's Avatar
Red454sedgwick
I'm working on a 1983 f350. The old carb is warn out and needs replaced. I'm looking at the holley two barrels. What size do I want? Is the 350 big enough or should I go with the 500? Also what size of jets should I start with?
The truck is a ranch pickup, it doesn't pull any thing. it just feeds cows and bounces though the pastures.
Old Oct 12, 2016 | 04:05 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What intake manifold are you going to use?
I don't know of a two to four barrel adapter that will cover the egr port "ear" in the stock intake.
Use the 500. 350 is going to have that big engine breathing through a cocktail straw any time it needs to climb a hill.
Decide on a manufacturer, then look at their recommendations.
If you said you wanted jetting for a Holley 600 or 750 on a stock engine there would be answers in the 'carbs by list #' tech info on their website.
Old Oct 12, 2016 | 08:46 AM
Plowboy34's Avatar
Plowboy34
you sure it has a 2 barrel now, I worked for Ford back then and don't remember any 460's with 2 barrels. Although drugs were involved back then so the memory may be not to good....
Old Oct 12, 2016 | 10:03 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I know some '70's cars had a big two barrel, but I haven't seen a pickup truck with one.
I guess anything's possible with first year introduction.
Old Oct 12, 2016 | 11:47 AM
InfantryCPT's Avatar
InfantryCPT
I threw a 600CFM Edelbrock on my daughter's plenty of power in it
Old Oct 12, 2016 | 12:11 PM
matthewq4b's Avatar
matthewq4b
If I recall correctly the 460 was never fitted with a 2 BBL carb the 429 was but the 460 never was . The 460 initially was the Lincoln engine and the 429 was found in the Fords.
Old Oct 12, 2016 | 12:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Okay, that makes sense.
The "short stroke 460" got the two barrel.
600 seems normal to me, with performance starting at 750 and going up from there.
Old Oct 12, 2016 | 01:33 PM
82F100SWB's Avatar
82F100SWB
Lots of 370 and 429's in F600 and bigger trucks with 2bbl's. I would not go smaller than a 500. The stock 4bbl of this era is a 600, but dont forget that the cfm rating is at a different level of vacuum between a 2bbl and 4bbl.
Old Oct 12, 2016 | 01:39 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Most of those medium duty trucks I've seen have governors on them as well. (at least the chip and bucket trucks I've worked on)
Old Oct 12, 2016 | 06:20 PM
Red454sedgwick
It has a ford-holley 4bbl on it now with a manual choke I'll have to check if I need that ear. I was just planning to use an adaptor plate.
Old Oct 12, 2016 | 07:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You need to *cover* the ear.
Or you will have hot exhaust gas erupting directly under your carburetor.
Transdapt makes a egr block-off spacer, but I don't think you can stack *another* inch under the carb and have the linkages fit up to your intended two barrel.
What's the point of a 2V carb anyhow?
Old Oct 12, 2016 | 11:57 PM
Red454sedgwick
save some fuel, and should be cheaper. you only use the extra barrels when going down the road and stand on it. this thing just farts around the ranch rarely seeing 55mph any more.
Old Oct 13, 2016 | 02:41 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You do understand that an engine is really just a positive displacement pump, right?
That your truck is going to draw in 460 ci of charge -every other- revolution, no matter what.
That *any* carburetor meters fuel to air flowing through it. (somewhere around 12--16:1)
I.e. each time the wheels turn an engine is going to pump a certain amount of charge through it.
And that charge is going to be ~1/14 gasoline -by weight- in order to fully burn, no matter what.
Old Oct 13, 2016 | 08:20 AM
matthewq4b's Avatar
matthewq4b
Not quite accurate.
That is the theoretical air handling capacity of the engine. The actual air flow or volumetric efficiency of the engine will be quite different.
The volumetric efficiency of most low performance engines at best is about 80% at peak torque (the point of highest volumetric efficiency in any engine is peak torque). All out performance engines only achieve about 95% VE at peak torque. To get beyond that you need to fine tune the induction system in naturally aspirated engines and this will only apply to a very narrow RPM range. Forced induction will allow you exceed 100% VE.
So in 1983 a 460 had peak torque of 390 ft.-lb. of torque at 2,000 rpm
Theoretical CFM
2000 x 460 = 920,000/3456 = 266 CFM
Actual CFM at 80% VE
460 x 0.8 = 368 CUI x 2000 RPM = 736,000 CUI Per min / 3456= 212.9 CFM
Or
460 x.8 =368 CUI x 1000 = 368,000 CUI Per min, convert to Cubic feet 368,000 CUI X 0.00057870 =212.9 CFM.
If you use the VE rule for engines it will help you size carbs.
So lets look at it at peak HP
the 1983 460 made 245 horsepower at 3,800 rpm
So we will still use the VE of 80% even though VE will be lower at peak HP.
We already know the CUI at 80% efficiency is 368 CUI
So
368 x 3800 = 1,398,400 / 3456 = 404.62 CFM
Spin that motor to 6000 RPM and
368 x 6000 = 2,208,000 /3456= 638.8 CFM
Also at 6000 RPM that engine is not going to be anywhere near max VE.
Old Oct 13, 2016 | 09:54 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So Ford was fairly accurate putting a 600 cfm carb in my 460 truck with a 5,800 redline.
it was a simplistic explanation.
Yeah, there are always pumping losses, and a broad powerband means VE is going to suffer somewhere in something this crude.
Race engines routinely achieve over 100% filling due to charge inertia.
High venturi velocity is good for atomization, but too small compared to runner volume is going to cause stagnation.
