hood pad replacement
Old Oct 10, 2016 | 10:59 AM
comsupany's Avatar
comsupany
Anyone have ideas or a source for inexpensive replacement for hood insulation pad for a 2002 Ford F450 and a diagram or part numbers I should order? I'm interested in replacing all of it and may need retaining clips too.
Old Oct 10, 2016 | 06:49 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Most just remove it when it becomes torn up or saturated with fuel/oil (from a leak). I do not have the PN for the pad. I am sure a quick Google search for it will yield you some results though.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Oct 10, 2016 | 08:08 PM
comsupany's Avatar
comsupany
So I don't have to worry about the paint bubbling on the hood because it gets too hot?
Old Oct 10, 2016 | 08:38 PM
CampSpringsJohn's Avatar
CampSpringsJohn
If it gets that hot, you have other issues than the paint bubbling.
Old Oct 10, 2016 | 08:41 PM
comsupany's Avatar
comsupany
Why do they put it in there in the first place?
Old Oct 10, 2016 | 08:47 PM
CampSpringsJohn
Noise in the cab. It absorbs some of the noise from the motor so it doesn't come through the hood. If you want to make it quiet, put some sound deadening material on the hood.
Old Oct 10, 2016 | 10:20 PM
weeeves's Avatar
weeeves
Sourcing one from a junkyard would be the cheapest option.
Old Oct 11, 2016 | 04:12 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Correct. Should never get that hot under the hood.
As stated, it is there primarily for noise. There is much better material out there to deaden the noise than the factory hood blanket though.
__________________
Justin
www.dp-tuner.com
Old Oct 12, 2016 | 02:53 PM
brian42's Avatar
brian42
Veteran: Navy
Part number is discontinued from Ford. You're only options are to find someone that doesn't want theirs or cruise junkyards.
Old Oct 12, 2016 | 03:03 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I removed the one from my truck, cleaned it with dish soap and water then let it dry. I think sprayed it black with spray paint and then remounted it under the hood. If yours is not torn or has holes, then you can follow this same practice. The one under my hood looks brand new and has since I cleaned it up 2 years ago.
Retaining clips can be found at most auto parts stores. If you have one to take with you to size it that would help a lot.
DISLTom
Oct 29, 2017 10:46 AM
Richwon4
Apr 25, 2017 10:10 AM
79mustang351w
Paint & Bodywork
Jul 21, 2012 02:47 PM
bismic
Aug 24, 2010 06:51 PM
Tilly03
Mar 31, 2004 09:54 PM
