HPOP line replacement
Old Oct 6, 2016 | 02:43 PM
derek0525's Avatar
derek0525
Well learned a lesson last night on the way home from work to check HPOP lines every now and then. It was actually the braided cross over line that burst and shut my truck down wich I just capped off the fittings off but when I was doing my search for what was wrong on the side of the road I also noticed that one of the HPOP lines the braided line was frayed. So I ordered new ones from clay hopefully they will be here this weekend but question is will oil drain out of the HPOP when I change the lines and if it does should I top off the pump before starting it?
Old Oct 6, 2016 | 03:12 PM
F250_'s Avatar
F250_
I had an early version of the soft crossover line fail on me as well, and have just gone back with the hard line on both my vehicles. I also proactively changed out both HPOP lines on my F250 almost two years ago when it was sitting at about 265K miles. Those hoses gave me good life, but I am now riding more comfortably knowing that there are new "young" lines in place while I drive today.
To answer your question, though, when I changed my lines, I did not top off the pump. I also don't recall seeing it recommended anywhere to do so. The pump will fill up fast enough when you go to start it back up.
Old Oct 6, 2016 | 03:18 PM
derek0525's Avatar
derek0525
Alright thanks. yeah my truck has 256k miles on it and I figure they need replaced.
duck fan's Avatar
duck fan
Because racetruck
That stinks, such a mess to clean up. Shouldn't need to top off the reservoir, it will be fine. You might have some air in the lines for a short time but it will work out in short order. It is funny how everything goes in a circle. I just saw the other day where a company is offering standard hydraulic lines for HPO and crossover lines. I guess they didn't notice how we tried that 10 years ago and it didn't work well, lol.
You are smart to change out your HPOP lines, they don't last for ever. I think Ford suggests ever 100k.
Old Oct 6, 2016 | 03:48 PM
derek0525's Avatar
derek0525
Yeah I got new IC boots and the plenum inserts to install also that I have had for over a year. Figure might as well do that at the same time probably make it easier getting the lines on and off.
Old Oct 7, 2016 | 03:56 AM
timmyboy76's Avatar
timmyboy76
I dumped the hpx because it seemed to make getting the turbo out, a bear to do. Anyhow, I replaced my hpo lines last year(220k) for the.. Just because.., and now have the originals in my door with the tool😉
Old Oct 7, 2016 | 08:38 AM
P4IN COMM4NDO's Avatar
P4IN COMM4NDO
That tool from RiffRaff is amazing. Gets em off in under a minute once you learn the trick to using it which is fairly simple. I used to mess with taking the fittings and whatnot off, then I realized it was only like $14. . .
Old Oct 7, 2016 | 09:09 AM
F250_'s Avatar
F250_
I had a piece of 1/8" flat bar at the house and just drilled and ground out my own HPOP line tool one day. It's a little crude looking, and surely doesn't look nearly as nice as Clay's, but I know for a fact that it works well and the line removal job is a snap.
Old Oct 7, 2016 | 09:33 AM
duck fan's Avatar
duck fan
Because racetruck
I think the were able to bring the price down because I lost mine I had for years and just bought another and it was only about $12 I think. I love how they have a bottle opener on the other end now too, great addition.
Old Oct 7, 2016 | 10:40 AM
P4IN COMM4NDO
sweet! I attempted to make one out of a fork, it kinda worked, but I just went ahead and got the right tool. . .
I just got mine a week or 2 ago, so either Im not remembering right or they lowered it not too long ago
Old Oct 7, 2016 | 02:30 PM
timmyboy76's Avatar
timmyboy76
I used the tool that comes with grinders. Ground it down and notched it. Worked perfect!
Old Oct 11, 2016 | 06:44 PM
carl2591's Avatar
carl2591
That a bummer for sure when a high pressure hose breaks cause they always break at a BAD time..
I change my OEM braided line out, which looked good, no frays etc., with the CNC high pressure replacement hoses.
CNC FABRICATION 7.3L E99-03 COMPLETE REPLACEMENT HPOP AND HPX LINE KIT CNC-SD-HPOPLINEKIT-HPX - Products
these are different than i got but better than the rest for sure.
Old Oct 11, 2016 | 08:57 PM
derek0525's Avatar
derek0525
The new updated ford hoses from riffraff are much better looking than the stock braided they look beefier.
Old Oct 11, 2016 | 10:30 PM
duck fan's Avatar
duck fan
Because racetruck
Companies did this about 10 years ago and after 2-3 years people started blowing lines and having leaks. Take it from personal experience just buy the Ford ones. If you are going to go for these type of basic lines just do what they are and have your local hydraulic shop make you some. At least then when they pop you are out less money.
Old Oct 12, 2016 | 03:03 PM
brian42's Avatar
brian42
Veteran: Navy
When I replaced my HPOP last summer it was chump change compared to what I was already spending with Clay for him to drop one in a box for me. No worries about measuring and fabricating was well worth the $13...and it's a bottle opener too.
T-wood
Feb 27, 2018 07:28 AM
rbsev
Aug 21, 2017 05:58 AM
timmyboy76
Jan 22, 2013 03:20 PM
92bruiser
Nov 4, 2011 07:54 PM
Dodge/Cummins
15
Oct 15, 2010 11:22 AM
