Well, I guess it's not called a starter bolt. Ford can't find it and I am thinking I may have to go to the junk yard. This bolt I need is really a transmission bolt. It holds the transmission, the spacer and the starter together. Does anyone know about this bolt.
Are you needing the bellhousing-to-engine bolts or the two starter mounting bolts? There are 6 total bellhousing mounting bolts - 2 shorter and 4 longer ones. IIRC, they are M12 x 1.75. Unsure of the lengths though.
All of the bolts on your truck are metric. Class 8.8 (Metric) is equivalent to Grade 5 (SAE). Class 10.9 = Grade 8.
I finally got it from the Ford Stealership lol. $17.80 Had to get a mechanic in their shop to come look at the pic I took of Location and he told Parts man where to find the bolt on his puter. Bell housing bolt is it. Weeeves got the specs right. Parts guy kept trying to sell me another bolt that was not it....$57 bolt lol. Go Figure. Thanks guys!
Take yourstarter bolt to your local hardware store.
Find a nut that fits yourbolt, then find the bolts that fit that nut. You have found the part(s) you need.
That's how I do it.
when I replaced my starter, I got the one that used 3 bolts (not 2) and used the locktite.
the bolts kept falling out prior to that and I almost lost my starter once... It was dangling by a bolt thread ... literally...
Make sure you clean the bolt holes real good with brake cleaner to get the grease and oil out.. that will help the locktite hold better..
