Broken Starter Bolt
Old Mar 18, 2007 | 04:03 PM
90efi's Avatar
90efi
Broken Starter Bolt
My starter on my 87 f150 5.0 went yesterday so today I decided to take my starter off before going to the parts store. Bottom bolt came out fine but the damn top bolt broke! I was surprised at this because I never had this happen before. Well I bought one of those extractor kits.... BIG mistake. The extractor broke in the bolt. Now I cant drill it anymore. I`ve tried vise grips but now the head is rounded. So does anyone know what I can do now? Please help.
Old Mar 18, 2007 | 04:11 PM
ACarbone624's Avatar
ACarbone624
You need to hit it with a torch and get it really hot and then try the vise grips....have you used any WD40? I've even heard if you tighten it a little, it might break it loose.....but I would say try the torch.
Old Mar 18, 2007 | 04:34 PM
90efi's Avatar
90efi
I thought that too but I dont own a torch.
Old Mar 18, 2007 | 05:44 PM
ACarbone624
Home Depot, Lowes or any local hardware store should have one...for about $20...that used those 1lb tanks. Should do the trick.
Old Mar 18, 2007 | 05:48 PM
F150xlt's Avatar
F150xlt
Heat the area around the bolt. I usually heat the area then spray WD40 around the bolt.
Can you get a small pipe wrench on it?
