2 bolt starter
Old Oct 14, 2014 | 08:33 PM
tbirdage's Avatar
tbirdage
2 bolt starter
I have a 2003 7.3 F 250 and broke an ear off my 2 bolt starter last week when the bottom bolt fell out. The bottom hole was stripped so I put a remanned high torque 3 bolt long starter back in it and was able to torque the stripped out bolt hole with a slightly longer bolt. What's the difference in these starters and why is a 3 bolt starter not listed for my truck? It bolted right in and man does it spin my engine good! Is there anything out there that I don't know about that I shouldn't have done this??
Old Oct 15, 2014 | 01:54 AM
JSchuricht's Avatar
JSchuricht
The 3 bolt starter is the older version that spins a bit slower. 2 bolt starters, OEM anyways, spin a bit faster. IIRC the changeover was late 2000. Either starter will bolt up and even a high end Denso starter only uses two bolts.
Old Oct 15, 2014 | 06:34 AM
whitetmw's Avatar
whitetmw
Since you were able to get the bottom bolt to at least thread, I would recommend some Blue Loc-Tite, just to be on the safe side. Steel only needs 5 threads to achieve Torque. But, you don't want it coming back out with a new starter installed in an aluminum casing.
Old Oct 19, 2014 | 10:40 PM
SpringerPop's Avatar
SpringerPop
As you've discovered, the hi-torque version of the Mitsubishi starters spin it over right-nice!
If I were ever in your situation, I would do the same thing you did, only intentionally!
Pop
7.3mule
Sep 14, 2008 07:10 PM
fiatman71
Feb 13, 2006 08:14 AM
aznative981
Bronco II
May 4, 2005 08:23 PM
Loganwildman
Apr 21, 2005 04:57 PM
