E4aod
Old Sep 22, 2016 | 12:48 PM
brian.b's Avatar
brian.b
E4aod
Hey guys will a automatic over drive tranny from say a 92 ford work in my 74 f100. Has any one done the swap and have a right up about......how much modifications need to be done......thanks
Old Sep 22, 2016 | 02:21 PM
HIO Silver's Avatar
HIO Silver
We are not clairvoyant...
You're forgetting to provide pertinent information like what engine it would be mounted to... and whether you know the "E" in E40D means electronic. Meaning, it would need, among other things, a controller and software.
E4OD and 4R100E Transmission FAQs - Baumann Electronic Controls, LLC
Old Sep 22, 2016 | 02:24 PM
4x4slik's Avatar
4x4slik
AOD and an E4OD are 2 different trannies. There is no e4aod. There is no specific write up on putting an OD tranny in a dent. Just need to search, read and learn. The AOD is a mechanical overdrive tranny and has a very particular linkage that needs hooked up and adjusted correctly or it will not work.
An E4OD is electronic and needs a controller and some sensors on the engine.
They are longer and bigger around than a c6. Drive shaft will need shortened. You also have a problem with speedometer. gear driven was not used much on these, but may have a spot and internals for a mechanical speedo.
It has been done, and there are a few articles on it out there, but a good detailed right up is not available that I have seen yet.
Old Sep 22, 2016 | 04:41 PM
brian.b's Avatar
brian.b
I just got a 74 f100 no motor or trans.....I'm looking for something to make this a daily driver I'd like it to be high geared or have over drive ......and motor wise I was thinking 302 or 351.....the truck originally came with a 390 auto
Old Sep 22, 2016 | 07:15 PM
4x4slik's Avatar
4x4slik
Well, then look for a mid to late 80's 302 or 351 with the AOD. This way it will have the proper linkage and no electronics. Should be still carbed. If you can find a donor truck, the better. If you find one that has same wheelbase and drive, 2wd or 4wd, then you should have everything needed for the swap, including motor mounts, crossmembers, drive shaft. and so on. That is what I would do anyway.
Old Sep 23, 2016 | 06:20 AM
matthewq4b's Avatar
matthewq4b
Alternatively you can go to an AODE (upgraded and Elec shift AOD) or a 4R70W (upgraded AODE) that will bolt behind a 302 or 351W. In fact both were offered in the F and E-series behind the the 302 and 351W and the 4.6L and 5.4L
The AOD AODE 4R70W and the 4R75W are derived from the the old FX/MX/FMX transmissions.
The E4OD (AKA 4R100) is derived from the C6.
After market shift controllers are available for both and just require the addition of a TPS (throttle position sensor) Most of the shift controller kits can be had with an add on TPS set up for a carb.
Personally I would opt for the 4R70W there is far more aftermarket support (Stand alone controllers, shift kits, upgrades ect) for the AOD family of transmissions than there are for the E4OD (4R100).
The 4R70W Will be adequate unless you are planning on doing lots and lots of heavy towing.
Hope this helps
briank
Aug 22, 2009 04:29 PM
IntheTrees
May 30, 2009 12:56 AM
macmillanracing
May 16, 2007 10:14 PM
danlee
Mar 30, 2007 12:30 PM
Nawahi
Oct 1, 2005 06:41 AM
