E4OD in 1980 F-100?
Old May 29, 2009 | 12:13 PM
IntheTrees's Avatar
IntheTrees
E4OD in 1980 F-100?
I bought a 351W to rebuild and the guy also gave me an auto tranny and transfer case. It came out of a 1992 F150.
I'm assuming it's an E4OD because it has a large multi pin plug on it.
I have a 1980 F-100 with a C6 that will need rebuilding soon. (It's slow to engage in D when cold)
The E4OD was apparently rebuilt a few years ago.
Is it possible to use this tranny in my truck?
Old May 29, 2009 | 01:35 PM
andym's Avatar
andym
You would need a standalone E4OD controller to run the tranny. Baumann engineering makes one, but it's not cheap.
Old May 29, 2009 | 05:26 PM
IntheTrees's Avatar
IntheTrees
Yeah, ouch, they are $550.
So I guess I'm probably better off getting an AOD if I want an OD tranny.
Is there any year I should look for or they all the same? Would I need a different driveshaft?
Old May 30, 2009 | 12:56 AM
85e150's Avatar
85e150
There is about a 3 inch diff in length between a C6 and the AOD, AOD is 30 3/8, C6 is 33 1/2, so you are going to need to change the DS. E4OD is longer than the C6 IIRC.
The AOD is a weak sister trans. What level are you going to build the 351 to? As for the preferred years, '88 to '93 according to one site. Early models had oiling and other issues, and were the worst for warranty claims, garnering more warranty claims than all previous Ford automatics, according to a knowledgable source right here at FTE.
A beefed AOD is over $2000, so consider where you want to spend your money on the trans, if anywhere.
TCI - Ford AOD, AODE and 4R70W
