Touchy ignition switch?
Old Sep 21, 2016 | 09:39 PM
katzklaw's Avatar
katzklaw
Just started doing this today... If I don't hold the key turned till just before the resistance point the truck dies as if I shut it off. In other words I can't just turn the key and let go when it kicks, I have to hold it and let go carefully and not let it spring back from the ignition's resistance or else the truck immediately dies. Any ideas?
Old Sep 21, 2016 | 10:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
My first suspicion is its time to replace the ignition switch. You can use the original lock cylinder so you won't have to change keys.
Old Sep 22, 2016 | 07:25 AM
katzklaw's Avatar
katzklaw
Ugh. How involved is that? I'm in the middle of a 2000 mile trip right now
Old Sep 22, 2016 | 09:50 AM
jbehuniak's Avatar
jbehuniak
Take about an hour or so. The switch removes by taking a screw driver and pushing it counter-clock wise against its retaining ring to unscrew it. There should be three indents in the retaining ring to do that with. Then swap in the new switch.
I cant get a picture of the wiring right now because I'm at work. If I remember I will take a pic of the switch and wires for you when I get home.
I forget it the connections are soldered or not that will make it a little more lengthy of a process to change the switch out.
Old Sep 22, 2016 | 12:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Nope, no solder, literally plug and play. If I remember correctly, the biggest part is swapping the lock cylinder, but since you have the key, that makes it much easier.
Here's a youtube video explaining it.
Old Sep 22, 2016 | 05:45 PM
Blue and White's Avatar
Blue and White
I'll just add there is an emergency backup. Get a spare ignition resistor wire and rig it with alligator clips. It may be a stock item at some AP stores. Jump coil positive to battery positive with the resistor wire and you will be able to run. Just don't forget to pull it when you stop.
I carry one behind the seat now after a new ignition switch had intermittent "open" and put me on the side of the road.
Old Sep 23, 2016 | 11:58 PM
katzklaw's Avatar
katzklaw
My husband took the ignition apart and cleaned it... Working better now actually. Maybe I can nurse it to my destination and replace there.
rob8210
Apr 1, 2013 05:40 PM
BPB
Jun 7, 2012 12:07 PM
brknight
Jan 2, 2011 09:13 PM
mep123
Electrical Systems/Wiring
Oct 23, 2003 07:31 PM
mikes66
Mar 4, 2001 01:25 PM
