My leaking c6
Old Sep 20, 2016 | 10:06 PM
Justin73supercamper's Avatar
Justin73supercamper
My leaking c6
I have a 73 f350 super camper special. It has a 390 with a c6. It has been leaking since I bought it. But shifts great doesn't slip. The fluid has always been bright red with no burn smell. So I don't want to pull it if I have to. I have replaced the pan gasket filter and vacuum modulator.curing leaks as I go. I'm down to a cover plate on the passenger side above the pan rail it has four bolts in it. What will come out besides fluid if I pull it off. Will I open a can of worms ? Or can I pull it get a new gasket and be ok? Thank you for any help
Old Sep 21, 2016 | 10:50 PM
jk080's Avatar
jk080
Transmission Rebuilder
Thats the servo cover, just remove the bolts and pull the cover off. You will find the servo and a spring, no worries just pull it all apart and clean it up including the case and reinstall it back with a new gasket and o rings.
Old Sep 23, 2016 | 11:06 PM
Justin73supercamper
Thank you . Now it is Time to fix the leak tomorrow. Sorry for not checking sooner
Justin73supercamper
Sep 22, 2016 11:00 AM
69WestCoastFord
13
Feb 26, 2009 10:19 AM
skyrader
Jul 31, 2008 03:57 PM
luckybturd
Escape & Escape Hybrid
Aug 29, 2007 08:14 PM
tjdude
Sep 17, 2003 07:04 AM
