1978 - 1996 Big Bronco
1995 Ford Bronco multiple issues
Old Sep 14, 2016 | 05:55 PM
1995Jeep's Avatar
1995Jeep
I have a 1995 Ford Bronco, Eddie Bauer edition. It's full size with a 1994 rebuilt transmission. I'm don't know a lot about vehicles so need something simple. The ABS light came on, then the speedometer stopped working, then shifting became hard at first and second gear, now the OD light is blinking. No check engine light. We changed the VSS and the neutral safety switch but no help. No blown fuses. OBD1 codes are 452,654,10,212.
Please help me. I don't want to sell her. She's in awesome condition for the year. Thanks in advance.
Old Sep 14, 2016 | 09:36 PM
Encho's Avatar
Encho
The Southernmost Mod
Are the other dials in the PSOM (dash) working?. You also need to retrieve those codes again, there will be only either 2 digit codes or 3 digit codes, not a mixture of both. See that the wiring to the transmission and the VSS isn't shorted, broken, or cut. Did you do anything before this symptoms developed? forded any water etc?.
Welcome to FTE!.
Old Sep 14, 2016 | 10:01 PM
1995Jeep's Avatar
1995Jeep
follow up to question
We did both the obd1 scanner and the flashing of the check engine lights and got the same mix of codes. We did ford some water a couple of weeks ago. Also water pump died and water went everywhere.
Old Sep 14, 2016 | 10:04 PM
1995Jeep's Avatar
1995Jeep
follow up to question 2
Sorry. PSOM dials all work except speedometer and odometer
Old Sep 14, 2016 | 10:29 PM
Tim Hodgson's Avatar
Tim Hodgson
E4OD transmission? And the OD light is flashing? You need to PM Mark Kovalsky here and ask him:
Ford Truck Enthusiasts Forums - View Profile: Mark Kovalsky
(The OD light is the "engine trouble light" for the transmission.
How many miles on the vehicle? The transmission? Still under warranty? Who rebuilt it?
Finally, see this thread for cleaning the contacts on your computer type plugs including the one that goes to your transmission:
https://www.ford-trucks.com/forums/1...o-files-4.html
Old Sep 14, 2016 | 10:43 PM
Encho's Avatar
Encho
The trasmission is in fail-safe mode right now, and it seems that somehow it isn't getting any electrical input, when I get some time I'll check those codes for you (still not sure how it's possible for you to get that mix). Try unplugging the transmission connector and cleaning it, same with the ECM (truck's computer).
Old Sep 15, 2016 | 08:08 AM
rla2005's Avatar
rla2005
The PSOM is part of the speedometer/odometer only. It has nothing to do with any of the other gauges/indicators.
If the odometer display is blank and the speedometer does not read anything while moving check Fuse 18. It supplies power to the PSOM with the key in the Run position. This is most likely the cause of your CM Code 452 (Computer detected an error in the VSS or PSOM signal during the last 80 warm-up cycles.) and the reason why the transmission is shifting hard and late. If Fuse 18 is good then you need to pull the cluster then inspect the PSOM board on the back for signs of damage.
As far as KOEO Code 654 (MLP sensor not in park position) is concerned check the sensor alignment on the driver side of the transmission.
"Code" 10 is not really a code, many code readers interpret the separator flash between the KOEO tests and CM (Stored Code) display as Code 10.
CM Code 212 (Loss of IDM input to EEC). This indicates the PCM, computer, is not receiving the Ignition Diagnostic Monitor signal from the Ignition Control Module. Most likely caused by using a gray colored ICM (Push-Start Ignition) on a truck (yours) using the Computer Controlled Dwell (CCD) ignition. You should have a black colored CCD style Ignition Control Module on the truck.
Old Sep 15, 2016 | 11:32 AM
Kemicalburns's Avatar
Kemicalburns
the 4wheel abs module located under the overflow tank could be bad. This was an issue on my 94 with same symptoms.
Search PSOM testing, you should find what pins need to be jumped on the abs control module connector.
Old Sep 16, 2016 | 02:00 PM
jjmtuttle's Avatar
jjmtuttle
Check the trans harness where it connects to the trans they make a repair harness for that for a reason mine was rotted out about 6 inches away from the connection had to rewire all of it with that he go sensor fun LOL also check the sensor in the rear end that affects a lot it's not only a abs sensor it's also deals with shifting and other issues hope this helps
Old Sep 16, 2016 | 05:16 PM
rla2005's Avatar
rla2005
As I previously stated if the odometer is blank (re:Post#4 "Sorry. PSOM dials all work except speedometer and odometer") the OP needs to determine if the PSOM is getting power or is otherwise damaged. Replacing the VSS is not going to do anything except lighten your wallet.
Old Sep 16, 2016 | 09:20 PM
Encho's Avatar
Encho
Just to clear things out, the VSS was already replaced.
Jude Hosey
Feb 2, 2017 08:12 AM
wileyeyejeep
Mar 19, 2012 02:21 PM
kellie
Dec 29, 2010 02:09 AM
gui88ford
1997 - 2003 F150
Dec 22, 2005 05:37 AM
kaos
1983 - 2012 Ranger & B-Series
Feb 3, 2004 03:47 PM
