73 f-100 V8 390
73 f-100 V8 390
Was not getting any fuel to the carb. I checked all the lines and they are all clear and pass air. Moved on to the filter on the carb, clean! Moved on to the filter attached to the bottom of the pump. Opened it up and found it filled with 3 inches of brown (rust i assume ) crap in the bottom of the filter canister. Changed the filter and reconnected everything . STILL nothing . I primed it by sucking the gas from the tank line to the pump. My question is could i have killed the pump with all that brown crap and should i change the pump , or could it be something else. PLEASE HELP ME
killerkjn
11-03-2005 02:58 AM
