f 100
Old Sep 7, 2012 | 03:17 PM
stallion3599's Avatar
stallion3599
f 100
I have a 66 f 100 with a 77 cid 300 in it. I just had the 1 barrel carb rebuilt.
I have new fuel lines and 2 fuel filters I bought.
I was thinking of one filter before the fuel pump and one after the fuel pump.
How does this sound? any suggestions or input is appreciated.
Scott
Old Sep 7, 2012 | 05:21 PM
f5fordgirl's Avatar
f5fordgirl
I would think one filter before the pump would be enough, but its your truck, add the second one if you want.
Old Sep 7, 2012 | 05:39 PM
schoo's Avatar
schoo
do you have one on the fuel pump now?
Old Sep 7, 2012 | 06:51 PM
stallion3599
It had one filter after the pump about a foot or so before the carb. The truck had sat and I drained the tank before and added new gas, I drained it again and am going to run a gallon of clean gas/treatment through it. The original filter was small and had rust "dust"
in it. I just wondered if anyone had any reason why a 2nd filter couldnt be added.
Scott
Old Sep 7, 2012 | 08:05 PM
63' f100's Avatar
63' f100
It will make it harder for the pump to pump fuel, but I honestly can't say how much of a factor that is.
Old Sep 8, 2012 | 04:34 AM
jowilker's Avatar
jowilker
Scott, Does the fuel pump have a cartridge filter in it? It should, & you might want to replace it.
With a large filter at the pump, 1 before the carb should be enough.
John
Old Sep 8, 2012 | 06:41 AM
ul37's Avatar
ul37
I have the stock pump with the canister filter on it and I also run a small universal filter at the fuel tank. Always have plenty of fuel at the carb.I know its not needed but it makes me happy.
Old Sep 8, 2012 | 06:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
240/300 I-6 fuel pump has a round metal cannister that thread onto the top of it. Inside the cannister is this:
C4AZ-9365-B .. Corrogated Paper Cartridge Fuel Filter (Motorcraft FG-1A).
Some peeps are unaware, so they install an inline fuel filter. Meanwhile, the fuel pump filter is getting more clogged up every day.
Same 1964/79 I-6 & V8 all FoMoCo vehicles. Available from Ford/autoparts stores.
Old Sep 8, 2012 | 01:59 PM
stallion3599
fuel filter
my fuel pump has fuel line in and fuel line out. I did not see any screw in filter, possibly where the fuel lines connect will screw in and out. Hell I could possibly buy a new fuel pump since I already did the carb and all.
Is the fuel pump the same for the 240 and the 300??
Scott
Old Sep 8, 2012 | 02:15 PM
schoo's Avatar
schoo
Scott
does your filter look some what like this (this my 292 but its simular)
mine the filter is on the bottom
Old Sep 8, 2012 | 02:46 PM
stallion3599
no the fuel lines come out of the top. (where your filter is mounted) mine is mounted the other way or upside down compared to your filter. I would have noticed a giant F***** can. Thanks I know mine does not have a fuel pump filter.
SP
Old Sep 13, 2012 | 04:46 PM
Old Coyote's Avatar
Old Coyote
You're right Scott, my '75 300 cid does not have the older type pump with the cannister filter, so I don't think your '77 would. I have a filter between the tank and pump and never had a problem.
Old Sep 13, 2012 | 06:35 PM
stallion3599
I bought 2 filters so I will install the one and save the other one, I drained the gas and saw very very few particles, like 4 in 3 gallons of gas.
thanks for the input
SP
TexasTrash
May 15, 2013 10:29 PM
beardshadow
Sep 9, 2011 01:11 PM
GeneStoner
Jan 13, 2003 07:22 PM
jgrasty7
Sep 18, 2002 09:00 PM
