in-line fuel filter
Old Sep 16, 2002 | 10:38 PM
jgrasty7's Avatar
jgrasty7
in-line fuel filter
Does anyone know where I can get a diagram of the engine on a 73 F-100 Ranger XLT, it has a v-8 360? I was wanting to install an inline fuel filter and I don't know where I would put it? Any help is appreciated.
Old Sep 16, 2002 | 10:55 PM
Jimbare's Avatar
Jimbare
all alone in the world
in-line fuel filter
put an inline filter between the tank and the fuel pump. that way it keeps trash from stopping up the fuel pump. it is not a bad idea to run 2 filters, one before the pump, one after the pump.
Old Sep 17, 2002 | 11:33 AM
jgrasty7's Avatar
jgrasty7
in-line fuel filter
I'll begin by saying i have practically no automotive skill whatsoever. That said where is the fuel pump? Also will I have to do anything to keep fuel from pouring out of the lines when cut or is it vaccum or what? Thanks
Old Sep 17, 2002 | 12:28 PM
jalampi's Avatar
jalampi
in-line fuel filter
Drivers side of the motor next to the oil filter.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Old Sep 17, 2002 | 04:41 PM
Redn99's Avatar
Redn99
in-line fuel filter
Make sure you relieve any pressure in the line, before cutting it, by loosening and then replacing the gas cap, just before you cut the line. Have the filter at hand and ready to put in place as soon as you cut the line. Be careful not to get gas in your eyes. Make sure you don't let gas run down your arm and get in your arm pit. Really, really stings!
Old Sep 18, 2002 | 05:15 PM
ThePsychologist's Avatar
ThePsychologist
in-line fuel filter
On my 360, the fuel pump has a built in fuel filter with a replaceable element.I believe the pump assembly was an AC/Delco #ACD-41124 ( $27.00) and just the filter element itself is a Fram # CG-20 for $2.24.
Old Sep 18, 2002 | 05:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
in-line fuel filter
Get a Ford manual for your truck. There are CDROM manuals available at the FTE [link: motorhaven.autoanything.com|Online Store] they have fuel system diagrams in them as well as all kinds of info.
Old Sep 18, 2002 | 08:51 PM
76supercab's Avatar
76supercab
in-line fuel filter
Welcome to FTE. There are 2 styles of fuel pump on the FE family of motors (360, 390, 428 and others). One has a filter on it and the other doesn't. If the pump has a filter it will have a screw on cannister on the bottom of the pump that almost looks like a mini oil filter. This is a cover and the fuel filter is inside it. If the pump doesn't have a filter on it then there is probably a filter at the inlet to the carb. Look for a steel line that runs up the front of the engine block and goes to the front of the carb. That is the fuel line. The pump will be at the bottom end of the line. If there is a filter at the inlet to the carb it will be a small (1 inch in diameter 1.5 inches long) metal can with a hex on it that screws into the inlet of the carb.
Old Sep 18, 2002 | 09:00 PM
Ferrite's Avatar
Ferrite
in-line fuel filter
mfire138
Dec 31, 2011 07:59 AM
BigRed1967
Nov 15, 2009 11:16 AM
Brian Hesting
General Diesel Discussion
Apr 21, 2009 10:22 AM
rweibel
Jul 25, 2005 10:02 PM
bearcub_46
Jul 27, 2003 12:39 AM
