A/C compressor help
Old Sep 3, 2016 | 12:30 AM
85MOTORSPORTXLT's Avatar
85MOTORSPORTXLT
A/C compressor help
On my 85 Ford F-150 I am currently installing the serpentine pulley setup off of a 1990 Ford F-150. I'm trying to figure out what a/c compressor I need, and I keep coming up with this part number… E6DZ19703A. Can anyone tell me what compressor this is? Thanks, Chris
Old Sep 3, 2016 | 07:39 AM
Franklin2's Avatar
Franklin2
Logically would you not use a compressor off a 1990 f150? You may have to change your lines to fit. And they may or may not fit the fittings on the other parts of the system.
Old Sep 3, 2016 | 08:14 AM
CountryBumkin's Avatar
CountryBumkin
I did a similar swap on my 1982 belt drive to a 1990 serpentine setup. I had to use the Compressor, Hoses, and Accumulator for the 1990 year. The Condenser and Evaporators did not need to be swapped.
Of course, this also required changing pulleys on the crank, WP, and Alt (and using the belt tensioner from the 1990).
Old Sep 3, 2016 | 10:31 AM
85MOTORSPORTXLT
I can't use my 85 compressor because the mounts don't work for the serpentine setup.
Old Sep 3, 2016 | 10:32 AM
85MOTORSPORTXLT
That's what I needed, thank you very much!
Old Sep 3, 2016 | 01:08 PM
CountryBumkin
Your welcome.
But note that my turck is an 82 F250 w/ 460, so setup may vary somewhat. You can see a picture of it in my "gallery".
Good luck
Old Sep 3, 2016 | 10:39 PM
85MOTORSPORTXLT
I'm running a 302, but the all the a/c stuff is the same so I should be fine
DidieX
Nov 13, 2015 01:03 PM
chdairy7
1997 - 2003 F150
Aug 7, 2011 07:23 AM
97Handshaker
1997 - 2003 F150
Aug 13, 2006 05:18 PM
samralh
Mar 11, 2004 07:04 PM
jayvee
Feb 13, 2001 05:51 PM
