On my 85 Ford F-150 I am currently installing the serpentine pulley setup off of a 1990 Ford F-150. I'm trying to figure out what a/c compressor I need, and I keep coming up with this part number… E6DZ19703A. Can anyone tell me what compressor this is? Thanks, Chris
Logically would you not use a compressor off a 1990 f150? You may have to change your lines to fit. And they may or may not fit the fittings on the other parts of the system.
I did a similar swap on my 1982 belt drive to a 1990 serpentine setup. I had to use the Compressor, Hoses, and Accumulator for the 1990 year. The Condenser and Evaporators did not need to be swapped.
Of course, this also required changing pulleys on the crank, WP, and Alt (and using the belt tensioner from the 1990).
I can't use my 85 compressor because the mounts don't work for the serpentine setup.
