a/c compressor bypass
Old Feb 12, 2001 | 04:01 PM
jayvee's Avatar
jayvee
The bearings are going out on my 92 F150, 302. Is there a way to bypass the a/c compressor, maybe by using a shorter belt? I don't have the cash to replace the compressor right now. Thanks!
Old Feb 12, 2001 | 04:31 PM
duneboy's Avatar
duneboy
I know they make an a/c eliminator bracket for your truck it's about $50 at your local ford dealer and you will also have to buy a smaller belt.
Craig
Old Feb 12, 2001 | 05:25 PM
otto's Avatar
otto
No doubt you could use a shorter belt as long as everything else will still run in the right direction
Old Feb 12, 2001 | 09:10 PM
Guy's Avatar
Guy
I got rid of my A/C compressor for the same reason and bought a bracket from ford that is a direct bolt on and I still use the same belt. Around $38
'92 F150 XL 4x4, 5.0L AOD, Headers, K&N Air Filter, 3.55 Gears, 31x10.5x15 Tires.
Old Feb 13, 2001 | 02:47 PM
bjoern's Avatar
bjoern
Hmm. Could I leave the A/C in there and just use a shorter belt? Might save some friction in winter. Or is the little friction in the A/C clutch not worth the hassle?
Old Feb 13, 2001 | 05:51 PM
loudfords's Avatar
loudfords
Neo01
Feb 9, 2015 10:17 AM
jesuscowboy
Aug 12, 2014 08:23 AM
rainman123
1978 - 1996 Big Bronco
Jun 19, 2005 06:19 PM
TexxinOhio
Jan 21, 2004 11:54 AM
