Ordered my carpet kit installation tips please
Old Aug 30, 2016 | 01:31 PM
Justin73supercamper's Avatar
Justin73supercamper
I ordered a carpet kit for my 73 super camper today. Any installation tips. Will be greatly appreciated since I have never installed carpet before. Should I glue it to the floor? Any tips will be helpful. This is one of the last things for the interior and want it to look good and not like a armature put it in
Old Aug 30, 2016 | 02:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No, don't glue it to the floor.
One "trick", when you get ready to install it, do it on a sunny day. Take the carpet and spread it out in your yard/driveway/parking lot for a couple of hours before you're ready to install it. The sun will get it good and warm and make the installation a lot easier. It makes it easier to smooth out the wrinkles too.
When you install, get it as smooth as you can but if all the wrinkles don't come out, don't sweat it. The wrinkles will disappear on their own.
Any holes that you need to make (seat belt anchors, seat hold downs, etc.) DON'T use a drill bit! You will regret it very quickly! Use a sharp razor blade and cut a small "X" where you want the bolt to pass through. If you aren't sure of exactly where the hole is located, get up underneath the truck and use a nail, awl or something similar to pierce the carpet from underneath. That way you'll be "spot on" on the hole's location.
Any trimming you need to do, use a sharp blade and be conservative on your cuts. You can always trim more, it's kinda hard to add it back on.
Old Aug 30, 2016 | 04:00 PM
HoustonDave's Avatar
HoustonDave
Like the man says - measure twice, cut once. For small screw holes, use a sharp awl, test light probe, or similar to feel around to locate the hole in the metal beneath. Now is also a good time to put down sound deadener or heat insulation under the carpet.
Old Aug 30, 2016 | 06:57 PM
HIO Silver's Avatar
HIO Silver
Line with Boom Mat, Dynamat, or an equivalent product!
Tuck the carpet under the firewall pad.
Pre-install the hardware on the floor like high beam switch, seat brackets and seat belt bolts. Position the carpet and cut an X on the heads to push them through. Alternatively, cut an X and then with a soldering iron melt the carpet fibers and backing.
Do not glue.
Prior to installation, set the carpet out in the sun on a warm day so it is more pliable (and cooperative!) immediately before installation. Plan ahead.
Old Aug 30, 2016 | 07:19 PM
Justin73supercamper
Thank you much you guys. I'm going too follow all the information you guys have. And post some before and after pics.
Old Aug 31, 2016 | 07:55 AM
scott79's Avatar
scott79
Like Mike and HIO said...and you can use a hair dryer after you have installed and positioned to smooth out some of the wrinkles!!
Outlaw56
Apr 6, 2015 11:37 AM
march
Aug 15, 2013 09:39 PM
mlevario99
29
Feb 21, 2010 07:43 PM
Narwhal
Jul 1, 2005 12:25 AM
spencry25
Sep 14, 2003 03:15 AM
