Installing a rug - molded or flat?
Old Jun 30, 2005 | 07:19 AM
Narwhal's Avatar
Narwhal
Getting ready to remount the cab and put in the carpet on my '53 F100. I went with a non-stock paint (Crystal Blue metallic) and want to both quiet the cab and hide some of my less-than-stellar fiberglass work at the floor joints.
Given the topology of the 53 floor pan, do I need to get a molded rug or can I install a flat rug, trimming as I need to. It's the transmission hump that has me concerned. Advice?
-Scott
Old Jun 30, 2005 | 02:01 PM
imlowr2's Avatar
imlowr2
I went the molded route carpet. Actually, after doing my carpet, you could use either method. The molded didn't appear molded rather a square piece of carpet which still needed trimming. As for the transmission hump, the carpet will lay down. It looks a little lumpy at first, but after a while the carpet lays flat. The molded carpet was easy to install, but I'd probably save some money and use standard carpet from a carpet store next time. The molded carpet come with the heel pad also, if that's important to you.
Old Jun 30, 2005 | 02:32 PM
55FordLover's Avatar
55FordLover
In the same boat also....didnt know which kind of carpet to go with....going to start installing next weekend since my brakes want to act up....after the carpet...then the glass in the doors...
Old Jun 30, 2005 | 04:11 PM
Jag Red 54's Avatar
Jag Red 54
I had my upholstery guy use two rectangular pieces of split pile. The first piece is mounted under the seat rails. The second piece covers from under the dash and overlaps the back portion. The SS strips in the doors hold down the edges. This way, I can geet into the under-floor battary compartment by just removing the door trim and pulling back the carpet. Jag
Old Jul 1, 2005 | 12:02 AM
imlowr2's Avatar
imlowr2
I have some great pics of my interior project in my gallery. May give you some ideas?
Old Jul 1, 2005 | 12:25 AM
edsf100's Avatar
edsf100
Got a deal on a carpet kit for the floor. Left the old there and placed the new on top. Helped with the sound. For behind the seat I went to Home Depot and got a carpet 6x9 and had enough left over for the kick panels. Came out pretty good for a low price. Door panels and headliner are next. Gallery has one pick.
fightlivefree
17
Nov 16, 2020 10:25 AM
Pony Power
Nov 17, 2014 08:33 AM
redman84
Jan 9, 2012 08:15 PM
desoto dave
Sep 9, 2008 10:09 PM
just-n-time
Dec 4, 2007 08:43 PM
