Dorman APS
Old Aug 29, 2016 | 09:31 AM
timmyboy76's Avatar
timmyboy76
Dorman APS
Accel position senor... Since mines a L99, I can replace just that? Worth the **** out sick to OEM?
Old Aug 29, 2016 | 10:53 AM
Rob K's Avatar
Rob K
Something I've learned here, ALWAYS OEM for sensors for these trucks.
Old Aug 29, 2016 | 11:07 AM
carguy3j's Avatar
carguy3j
In some cases (ICP, CAM SENSOR, IPR), you really want to stick with oem. However, in this case, the Dorman should work fine. It's just a glorified rheostatl and is functionally no different than any other TPS that Dorman and others have been making for years.
I've had no problem with the Doramn APPS sensor that I have had for over a year.
Also, I'm not even sure Ford will sell you just a sensor. I think they want you to buy the whole pedal assembly.
Don't forget to check your IVS while you're there.
Old Aug 29, 2016 | 12:16 PM
Pikachu's Avatar
Pikachu
Standard makes just the sensor as well. P/N T92001, less than $40 on Rock Auto.
FordRacing85
3.8 & 4.2L V6
Aug 11, 2021 09:51 PM
JOHN2001
Aug 9, 2012 09:21 PM
bigbubba87
38
Dec 13, 2010 07:42 AM
outlaw75
Aug 13, 2004 01:57 PM
TommyH
Jul 31, 2004 09:58 AM
