Going Away!
Old Aug 31, 2016 | 10:04 AM
Pkupman82's Avatar
Pkupman82
Originally Posted by sean9049
As the title states, I am going away, for at least 4 years(Army). I plan on giving my truck to my parents since I have put waaay too much money into it to sell. I am going to pull the motor and fix the annoying *** leaky oil pan, and replace the oil cooler since it looks questionable and I would rather not leave it to them to deal with it.
Is there anything else I should do to it while it is out of the truck; preventative problems in the future type way. I know it sounds stupid to fix something that ain't broke but if it makes one less headache for my parents ill do it.
As always i appreciate any advice and input from you all!
Army, really?! Ugh, you should have went into the Marines! Just kidding brother, I did 4 years in the Corps myself (2002-2006). Actually in your case the Navy (Corpsmen) would have been the place to go. Those are some big shoes you're about to fill guy! I thank you for your service, best wishes and GOD BLESS!
Old Sep 1, 2016 | 07:05 PM
sean9049's Avatar
sean9049
The Navy/Air Force both told me there was not going to be any corpsman jobs until at least the end of the fiscal year(really?!). Army it was!
Order has been placed, $900 doesn't go too far in the diesel world does it! pics and questions to come, I'm sure.
Old Sep 11, 2016 | 10:36 AM
sean9049's Avatar
sean9049
Well I didn't get nearly any pictures since mine and Doug's hands were covered in grease the whole time. The motor is out, that took about 11 hours, on Friday, working slow and we spent about 3 hours on the fan clutch...I ended up making my own tool out of a 1 7/8 wrench.($35 down the drain) reason being the fan clutch tool was slightly too big and the nut was slightly too rusty.
DougJ_1997PSD drove about 1.5 hours to come and help me get it done, not only did he show up early but he was ready to work. He even brought his own tools! Good help is hard to find, but this forum doesnt disappoint.
Now time for questions..
water pump pulley, when I spin it, it sounds like the bearing are bad. I cant tell whether the pulley is bad or the water pump. Is it worth pulling the water pump off to look at?
the oil 4 plugs have some metal crap in them that makes it so I cant put an extension all the way in, I haven't tried to take them out yet because the motor is outside and the parts don't get here until tomorrow...hopefully. Do you just get the extension in as much as possible then hope it doesnt strip?
In the pictures below you will see that the coolant passages from the oil c
ooler look...rusty/blemished. whats the call on that?
Rusty
Dirty?
how it sits today
day one complete
Old Sep 13, 2016 | 12:21 AM
79jasper's Avatar
79jasper
Not sure what 4 oil plugs you're talking about.
Water pump pulley can't really go back. There's nothing between it and the water pump snout.
Replace the water pump.
Old Sep 13, 2016 | 07:58 PM
sean9049's Avatar
sean9049
I pulled the water pump...it made even weirder sounding noise when it was off. metal-metal type noises so i replaced it.
how does this look?
I put the new oil rail plugs on, new oil cooler, which was a lot easier than its made out to be IMO. put the new water pump and fuel lines on.
Dont make fun of the half started primer...it will be black before it goes back in..lol
I spent about an hour getting all the old rtv off the oil pan only to turn it over and see a crap ton of pitted rust so I'm buying a new one tomorrow. it just makes sense since its such a hard job to get to the oil pan.
IDIoit
May 17, 2017 12:37 PM
71FoMoCo
Oct 29, 2013 11:53 PM
Ford79
15
Apr 22, 2011 09:15 PM
Dieseldan7.3
Mar 14, 2007 09:40 PM
andywe
Oct 6, 2006 10:03 PM
