D60 hub/axel exploded view and part numbers
Front Dana 60* bearings and Seals
Inner Spindle seal # 57: Timken 710044
Part Number
Mfr
14012967
GM
3894121
CHRYSL
4089297
CHRYSL
47698
VICTOR
620062
DANA
620062
SPICER
710044
ABI
710044
TIMKEN
711822
C-R
D8TZ1175C
FORD
Outer spindle seal #59 Timken 710045
Part Number
Mfr
37311
DANA
37311
SPICER
462811
GM
47623
VICTOR
710045
ABI
710045
TIMKEN
400659
C-R
D8TZ1175A
FORD
Spindle needle bearing #60: Timken B2414
Part Number
Mfr
112821R91
IHC
1400967
GM
4089296
CHRYSL
528103R91
IHC
620063
SPICER
9424050
GM
B2414
F-M
B2414
TIMKEN
D8TZ3123A
FORD
FB2414
SEAL-P
M201321
TWINDI
B2414
C-R
S2414
INA
SCE2414
INA
Spindle seal and bearing kit - #s 57, 59, 60: Timken SBK3
Part Number
Mfr
14009626
GM
4086641
CHRYSL
700014
DANA
FSBK3
SEAL-P
SBK3
F-M
BK3
C-R
SBK3
TIMKEN
Wheel Bearing hub seal #63: Timken 415960
Part Number
Mfr
27452
SKF
415960
TIMKEN
27452
C-R
48816
SPICER
Inner wheel bearing cone (bearing) #64 - left: Timken 387-AS
Part Number
Mfr
10X15157
WHITE
1331445600
ARAMCO
181267
WABCO
206087M1
MASSEY
218285
A-C
2182855
A-C
243146
RIV
319014
AUSTIN
327195R91
IHC
387AS
NTN
387AS
TIMKEN
49030
NEWHOL
49X50209A
DEERE
4T387AS
NTN
565906
SPICER
613862C91
IHC
826926C91
IHC
9436882
GM
9500172
JOY
95X387AS
JOY
A629826
GERLIN
C5NNA767A
FORD
C7TZ1244A
FORD
F387AS
SEAL-P
JD8147
DEERE
Inner wheel bearing cup (race) # 64 - right:* Timken 382-A
Part Number
Mfr
0009813580KZ
M-BENZ
0009814581KZ
M-BENZ
053146
RIV
105497H
IHC
10578
A-C
107845A
WHITE
10A7292
WHITE
111E050032
AM
111E0500321
AM
1331442400
ARAMCO
142223
GM
149505
MACK
150805
JEFREY
167717C1
IHC
195521M1
MASSEY
195525M1
MASSEY
196068M1
MASSEY
1AE0334
WHITE
20641
EATON
207234H1
IHC
212037
A-C
2150007
GOODMN
2150007
WABCO
3010578
A-C
30105787
A-C
313037
AUSTIN
354T5
WHITE
382A
NTN
382A
TIMKEN
384350R1
IHC
388533R1
IHC
392689R1
IHC
3950457
GOODMN
45733
HYSTER
471489
WABCO
49029
NEWHOL
4T382A
NTN
516149E
WHITE
520013
GEHL
545905
EATON
550583
SPICER
568500
CHRYSL
591674C1
IHC
62908
JEFREY
64AX148
MACK
658998
CLARK
664736
SEAL-P
723873EB
EATON
7451691
GM
7XA315
WHITE
826925C1
IHC
84816
VERSAT
890132H1
IHC
90162
WHITE
919661
AMC
9600172
JOY
96X382A
JOY
984363C1
IHC
9A382A
FWD
A629827
GERLIN
C5NNA768A
FORD
C5NNP777A
FORD
CBX2011
WHITE
D44932A
GALION
F382A
SEAL-P
JD7425
DEERE
KW1583
KENWOR
OX35076
DEERE
RT8109A
WHITE
RT9009A
WHITE
RX2903
MASSEY
SK20327
CLARK
T9424
*****H
TCAA1243A
FORD
TM3278
WHITE
VX3437
WABCO
X48313
A-C
Y382A
CHRYSL
Outer wheel bearing cone (bearing) #65 right: Timken LM104911
Interchange Number
Mfr
1331928200
ARAMCO
287066
NEWHOL
2953549
CHRYSL
2955374
CHRYSL
364462C1
IHC
431667C1
IHC
4TLM104911A
NTN
565918
SPICER
7451813
GM
8128842
AMC
9428539
GM
C7TA1239A
FORD
C7TZ1239A
FORD
LM104911
NTN
LM104911
TIMKEN
Outer wheel bearing cup (race) #65 left: Timken LM104949
Part Number
Mfr
1331928500
ARAMCO
2825729
CHRYSL
2852729
CHRYSL
2852729
GM
2953550
CHRYSL
364463C91
IHC
431668C91
IHC
4TLM104949
NTN
5357401
AMC
565905
SPICER
591651C91
IHC
7451814
GM
8128841
AMC
929742
A-C
9428909
GM
C7TA1240A
FORD
C7TZ1240A
FORD
FLM104949
SEAL-P
J5357401
CHRYSL
JD9070
DEERE
LM104949
NTN
LM104949
TIMKEN
LM104949JX2
NTN
Outer wheel bearing cup and cone set (bearing and race) #65:* Timken SET38
Part Number
Mfr
364464C91
IHC
431669C91
IHC
46AX90
MACK
7451812
GM
9428908
GM
A38
F-M
BR38
C-R
BWLM104949LM1
NTN
E5TW1239AA
FORD
E5TW1240AA
FORD
FS38
SEAL-P
K38
KOYO
LM10494911
ALL
NO.38SET
SKF
NO38SET
SKF
S38
APEZON
S38
L&S
S87
GREEN
S87
HYATT
S87
NDH
S87A
HYATT
S87A
NDH
SET38
TIMKEN
Inner axle seal (not shown in pic) Timken 415960
Part Number
Mfr
123270
HYSTER
128576
CLARK
131526
SPERRY
15009
OEM
15527650
GM
15532846
AMDSO
215272047
GARLOK
22719
GARLOK
233012
HALLSC
290768R91
IHC
298714
DELOO
30131718
A-C
32719
GARLOK
34319
VICTOR
35624812
TROSTL
3J0375
CAT
3J375
CAT
415960
ABI
415960
TIMKEN
415960
ABI
42719
GARLOK
43058
TROSTL
455960
OEM
47108
BOSTON
475960
NATION
52719
GARLOK
609108
THIOKL
62508
VICTOR
62510
DANA
64116
VICTOR
66X2047
GARLOK
7046910
GMCOM
812059
AMWHEE
859056
WHITE
918405
AMC
92774
WHITE
A49004
TROSTL
AA8511E0
NOK
AD7408E0
NOK
D8TZ1175B
FORD
MOO508562
FWD
PGF4921
AUSWES
PR1374
REPCO
PR2294
REPCO
PR3812
REPCO
PR5213
REPCO
PR6274
REPCO
T2560
CHRYSL
UA0029E0
NOK
UA0029F0
NOK
I come up with 4 10 i know what that is then F6TA ?? whaere it was made? BGA ???
next line 610610 Model number ... f2 ?? I just want to get the correct seals. I found the Model . but there are variations.
- Dana 60 (Snowfighter) with King Pin Knuckles and 9.75" Gears
- Dana 60 (Non-Super) with Balljoint Knuckles and 9.75" Gears
- Dana 60 (Non-Super) with Balljoint Knuckles and 10" Gears
- Dana Super 60 with Balljoint Knuckles, 10" Gears and 1480 U-Joints
- Dana Super 60 with Balljoint Knuckles, 10" Gears and 1550 U-Joints
If it's leaking gear oil at the hubs, then you will need to replace the internal seals (not shown in the above diagram). You will have to pull the axles and remove the diff in order to get to them. There 1 and 2 piece designs; can't remember which ones are preferred.
"Beemer Nut"
03-17-2013 10:29 PM
bajafishnut
29
02-10-2013 01:33 AM
78ford351m
10-24-2010 10:32 AM
mitch_c
10-10-2006 07:49 AM
