Coolant
Old Aug 27, 2016 | 03:12 PM
Ethan Robinson's Avatar
Ethan Robinson
Coolant
I know this has been covered before. But I'd like some "updated" information. What's the consensus on the best coolant for 7.3 idi? ELC? Or just put SCAs in it? Reason I ask is I've had my truck since April. 2k left to an oil change and was gonna change coolant maybe. The coolant is still pretty green and I know the owner added a pint of SCA additive every so often. Also where is everyone's temp gauge running at? I feel like mine might be running cold
Old Aug 27, 2016 | 10:07 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The IDI was built during the times of regular green coolant with additives ... ELC's were not really being used yet at the time.
Is that saying ELC's are not good for it ... Nope!
Just not what it was designed for!
-Enjoy
fh : )_~
Old Aug 27, 2016 | 11:17 PM
Macrobb's Avatar
Macrobb
I am using Zerex HD ELC Diesel coolant, with (so far) no issues. It's pink, tastes terrible(<_<) and seems to work well enough.
Old Aug 28, 2016 | 05:27 AM
mebe2k's Avatar
mebe2k
I've had rotella ELC in mine for over a year now.. no problems.
Old Aug 28, 2016 | 06:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
i use prestone green with napakool in mine. 494,000 miles so far with no problems.
Old Aug 28, 2016 | 02:51 PM
Ford_Six's Avatar
Ford_Six
I ran LL universal yellow coolant in mine for four years without issue, on the new version it'll be red Delo ELC as that is the best stuff I have available at work.
Unfortunately pretty much anything will cool the engine, but the major concern is with cavitation. That may take years to show up, if at all.
Old Aug 28, 2016 | 06:52 PM
85F350IDI's Avatar
85F350IDI
I've always wondered where to find the SCA's
Old Aug 28, 2016 | 10:20 PM
Macrobb's Avatar
Macrobb
Napakool. Seems to be at every Napa I've been to, though the people behind the counter have no clue what it is.
Old Aug 29, 2016 | 08:44 AM
snowdog79's Avatar
snowdog79
You can get the test strips and Motorcraft SCA on Amazon.
Old Aug 29, 2016 | 08:19 PM
Ford_Six's Avatar
Ford_Six
Since the real need in these engines is cavitation resistance, why don't we use an ultrasonic cleaner to test a few types of coolant? It's not overly scientific, but those cleaners work by inducing cavitation. If coolant A makes fewer bubbles than coolant B, it would be safe to assume it had more cavitation resistance, right?
Maybe test a few different types, some old stuff, pre- and post- treatment coolant.
I may need to go get a cleaner again.
Old Aug 29, 2016 | 10:07 PM
Macrobb's Avatar
Macrobb
And that's a good theory... but I suspect you'll see no difference overall. The real important part of the coolant, IIRC, is that the additives will form a protective layer on the metal, so the bubbles erode that(which is then replaced) vs the underlying metal.
As far as reducing bubbles go, I think having more coolant pressure does that(in addition to increasing the boiling point.
bedwards
2015 - 2020 F150
Dec 9, 2018 06:03 PM
comingback2ford
Jul 14, 2013 03:57 PM
dandy250
Dec 18, 2007 11:01 PM
fhartell
Jan 1, 2004 06:44 AM
haakeye50
Jan 5, 2003 08:43 AM
