Does the upper ball joint rotate?
Old Aug 20, 2016 | 12:59 PM
crandallf150's Avatar
crandallf150
Finally got the camber adapter to reach the ball joint boot (first 2 ball joints measured .820 and .827 at the shafts widest) by returning one of the joints and getting a .820 to match the other side which fits perfect, now by tightening the nut to where the adjuster/spindle will reach the boot the ball joint shaft, adjuster and spindle all turn together and its hard to turn--the spindle on the other side rotates on the camber adapter...which is correct and what do I do to the side that's not...sorry about all the questions but I've never had so much trouble w a ball joint setup in my life!
Old Aug 20, 2016 | 05:13 PM
Franklin2's Avatar
Franklin2
It should not be turning in the camber adapter. That is the tapered shaft and should be locked tight. Only the ball part under the rubber boot should turn when spinning the spindle.
In other words, see the grease fitting? That part inside underneath the grease fitting is the part that turns(the "ball" joint). The shaft that comes down out of the rubber boot should be locked tight to the camber adjuster, and the camber adjuster should be wedged/locked tight to the spindle.
Old Aug 20, 2016 | 05:21 PM
crandallf150
Ok so it should all be turning with the spindle,the ball joint shaft,adjuster and nut? Also the other side,the spindle is rotating on the adjuster-not torqued correctly?
Old Aug 20, 2016 | 05:25 PM
Franklin2's Avatar
Franklin2
Yes, I think you have it now. Pull that castle nut up very tight. If you run out of castles again, add washers or something but get it very tight, you do not want this thing coming off.
Old Aug 20, 2016 | 05:30 PM
crandallf150
Yes I was having nightmares w this ball joint,apparently the Oreillys master pro Chinese crap comes in 2 different sizes,.820 and .827 and the adjuster ain't going on the bigger...
Franklin2's Avatar
Franklin2
My book says the upper balljoint castle nut should be tightened to 85-110ft lbs. The lower balljoint nut should be 104-146 ftlbs. Those are high numbers. Backyard translation: Use a 1/2" breaker bar and pull it on it pretty good, or a 1/2" ratchet with a short cheater pipe on it and pull it tight.
andrewrj
16
Apr 12, 2014 03:36 PM
Duke78
Jan 14, 2009 05:11 AM
tommyleea
Bronco II
22
Jan 8, 2009 06:24 PM
Beaned
Aerostar
Dec 26, 2004 09:56 PM
agillings
Oct 26, 2000 12:40 PM
