ball joint help
Old Jan 13, 2009 | 06:12 PM
Duke78's Avatar
Duke78
ball joint help
I got the spindles off, i put the ball joint press on the upper ball joint and started turning. That thing didn't budge. I noticed a collar in the ball joint socket, what is it and do i need to remove it before cranking on the ball joint? Please help...
Can the joints be removed while the inner and outer "C's" are together, or do i have to knock them apart first?
Old Jan 13, 2009 | 09:19 PM
OldMetal's Avatar
OldMetal
Take a wire brush and clean along the joint, some of them have a clip that will need to be removed. Also keep in mind these suckers are in there pretty tight.
Old Jan 14, 2009 | 05:11 AM
Duke78's Avatar
Duke78
The bottom ball joint has a snap ring i have that off, i've pushed so hard on the top ball joint that the stem is mushrooming. I thought maybe i'm gong the wrong way, or maybe i have to have the steering knuckle removed before pressing on the ball joint.
Also what is the name of the tool that can remove the upper ball joint collar? Looks like a 4 prong socket like a small spindle nut socket?
