TTB 44 driveshaft broken - non replaceable U joints?
Hi all, thanks ahead of time. '81 F150 here with, I believe, the usual Dana 44 in front. I managed to snap the yoke loops out on my slip joint pinion (hopefully I've ID'd it right) at the first U joint out of the front differential toward the passenger wheel. As far as I can tell this bearing is staked: no circlips and 'SPICER' in the end caps. It seems like I need to replace the stub shaft and slip yoke in order to replace the u joint BUT of course I can't find one. It seems like DennysDriveshaft carries a pinion yoke that I can't use - mine seems one piece with the stub axle:
http://www.dennysdriveshaft.com/c723_dana_44_ifs_front_ford.html
Rock auto lists axle components but the MFG, standard gear, doesn't list anything for a 44 TTB this old.
Am I **** outta luck? Is it time to start getting silly with remanufacturing this thing?
I really don't know enough about the older trucks to say what's right.
I'm just quoting from my printed catalog.
here's the page online: Dana 44 Axle Shafts-Broncograveyard.com
on
80-82/3 uses a pressed on bearing and seal, with a bolt on retainer, very similar to a 9"
http://www.quad4x4.com/cgi-bin/comme...cton&key=40173
That is the bearing/seal/retainer. I'm not having luck finding the shaft. JBG used to have it.
phaethon
05-02-2014 11:04 PM
piratius
12-27-2010 01:58 AM
Milwaukee1979F150
03-25-2010 09:13 PM
Eddie
02-24-2000 04:21 AM
