Steering Column Gasket
Old Aug 21, 2016 | 08:31 PM
  #31
ctubutis's Avatar
ctubutis
I use a handheld 5 lb mini sledgehammer for that kind of job, you need to use some force sometimes and beat on it hard - but I know how hard that can be given the limited access. Sometimes a combination of both works well, e.g. apply a puller device and pull from one side and then strike it with a sharp blow from the other side.
I have broken a cheap, Chinese-made puller from Harbor Failure before (friend let me borrow his), ever since then I get paranoid at the quality of some of today's tools.
It amazes me sometimes how businesses don't know how to accept people's money (or make change) when "the system is down." I saw something like that at Home Depot once, some central computer had crashed or sumthin' and absolutely no cashier knew how to accept cash, make change, and manually write a receipt. I left, I figured they don't deserve my money if they don't know how to accept it from me without a computer to help them.
Old Aug 21, 2016 | 09:15 PM
  #32
hharris8's Avatar
hharris8
I was using a 8 pound hammer and getting some pretty good blows from above though not perfectly straight down. I will try to find the puller somewhere and see if that works. I even tried to use a reciprocating saw to cut it an maybe release whatever was keeping it in there, but even with a metal blade it did not make a scratch.
I do not like buying from chains alone, let alone this AutoZone, but it is hard to find a mom and pop store with all the parts nowadays.
Old Aug 21, 2016 | 09:31 PM
  #33
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I have found supporting the pitman arm with a bigger hammer then you are hitting with helps transfer the shock into the joint helping it break loose.
Just beating on the pitman arm causes bounce and that absorbs the shock.
Yea, it's tight, they can be real tough to get out!
Also, if you are replacing the joint, you don't need to protect the end with a nut, just don't beat it up so bad you can't get it out of the arm.
Chris, I just walk out as well ...
Harbor Failure puller ... lol!
-Enjoy
fh : )_~
Old Aug 21, 2016 | 10:22 PM
  #34
ctubutis's Avatar
ctubutis
Another thing you can sometimes do is use a long (4' or so) pry bar, use one hand/arm to apply downward force and the other to strike from the top at the same time.
Old Aug 21, 2016 | 10:45 PM
  #35
ctubutis's Avatar
ctubutis
Oh, c'mon, Festus! Doing it that way - without the castle nut installed upside down - is dangerous to do; he could decide it's too much work/doesn't have any more time/whatever and wants to put it back the way it was and try again later. But if he's destroyed the threads, that will be really hard to do.
Harbor Failure - The Home of Single-Use, Chinese-Made Tools.
Old Aug 21, 2016 | 11:32 PM
  #36
Festus Hagen
Methanoholic
Yup, I agree, it is a no backing out situation, I did say "if you are replacing the joint" for a reason ...
And yes, I should of included a warning ...
The thing is, shock is what will get it out, the nut absorbs shock!
Besides I have faith in him, so far he has accomplished some pretty heavy things for a novice!
He'll get it, he doesn't give up easy!
I use pickle forks on the joint ... A puller to pull the pitman off the gear box.
Oh I knew what you meant ... I have a few Harbor Failure's in the scrap bin!
-Enjoy
fh : )_~
Old Aug 22, 2016 | 05:17 PM
  #37
Franklin2's Avatar
Franklin2
If you do not care about the rubber boot, a pickle fork will take it right off easily. $10 from Harbor Freight, they work fine. You don't pry with this thing, you hit on the end with a hammer and drive the wedge in to pop it loose.
Old Aug 22, 2016 | 05:20 PM
  #38
hharris8's Avatar
hharris8
I rented that along with the puller. It popped right out (with some heavy duty force, but I could not do it without it.)
Old Aug 22, 2016 | 06:00 PM
  #39
maytag906's Avatar
maytag906
Just gotta be careful when working around the pittman arm, and steering box. Too much banging and rattling "could" cause the lower seal in the steering box to start leaking.
Been there, done that, on a 79 F350.
Mike1
Oct 11, 2015 04:34 PM
Gatordog
Jun 22, 2015 05:55 AM
glovemeister
18
Sep 24, 2013 09:00 PM
Ben Quesinberry
Mar 26, 2012 05:20 AM
7700Rob
1997 - 2003 F150
Jul 19, 2006 10:08 AM
