There is a u-joinr under the dash.and several parts in the column.
allso on mine the track bar ends were worn.rebuilt it and it helped.that will let the body move before axle is actuated.
"It's a Ford" with a RedHead gear box and a real shaft with real u-joints, meaning all the "Fordiness" has been taken out of the picture. It should NOT be loose. Check the u-joints on the new shaft. We put a RedHead and a Flaming River shaft in our RCLB; one u-joint was bad right out of the box. They sent us a new one and it cleared up the looseness.
No track bar if it's the F250 in your sig.
See that is what I thought I really do appreciate that. I've just been kind of shocked with all the attention I've paid to steering and it really hasn't improved. I have been hearing rumblings that Redhead was pressed for time on the last group buy when I bought mine and they were sending out boxes that were not as good as they should have been.
Also good to know on the u-joints. I will verify that. I assume they are checked just like drive line joints?
Its an f350 and I think I've got a front track bar and rear sway bar.
