Fuel pump question
Old Aug 17, 2016 | 09:12 PM
Krose788's Avatar
Krose788
Fuel pump question
Ok so I have a 77 f250 and it has a 460 swapped in it.and it does have a manual fuel pump on it.now my problem is I need a gas tank since it never had one since I bought it and every gas tank I find for that year truck has a sending unit cut out on it.now my question is do I need a sending unit if I have the manual pump and if not what gas tank do I need to get?thanks
Old Aug 17, 2016 | 09:18 PM
dlburch's Avatar
dlburch
your tank needs the cutout, that is where the fuel supply and fuel level sending unit goes.
Old Aug 17, 2016 | 09:21 PM
Krose788's Avatar
Krose788
Ok thanks man I wasn't sure.I used to have a 69 Broncos when I was a kid and I only remember it having a 3/8 inch petcock and it has the same style fuel pump but that was years ago so I can't really recall
Old Aug 17, 2016 | 09:22 PM
HIO Silver's Avatar
HIO Silver
To build your street cred, please refer to your pump as a "mechanical fuel pump" rather than a "manual pump".
....... it's not a bug sprayer after all.
Old Aug 17, 2016 | 09:30 PM
Krose788's Avatar
Krose788
Didn't know I needed street cred to be a keyboard cowboy.but thanks for the advice,I'm no mechanic that's why I'm on here!
Old Aug 17, 2016 | 09:41 PM
351Cleveland C4's Avatar
351Cleveland C4
Pay attention and you'll learn a lot fast.
Old Aug 17, 2016 | 10:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Welcome to FTE, lots of good, knowledgeable people here.
On the fuel tank, all tanks have the fuel sender cutout and yes you will need it because the sender also contains the fuel pickup and strainer. That's where you hook the fuel line up to. Without it, you won't have any place to connect the fuel line.
One other thing you will need to know. There are two different aft-axle tanks for these trucks. They're usually listed as with or without emissions hole. What that is, is some trucks came with evaporative emissions systems and some came without the system.
Systems with evapoartive emissions have a hole in the center top of the fuel tank for a check valve to fit. Systems without didn't have the hole.
To know whether your truck has evap emissions, look for a charcoal canister bolted to the passenger frame rail in the engine compartment. There will also be a 5/16" hardline running along the passenger frame rail from the canister back to the fuel tank.
Here's a tank with the emissions check valve and a close up of the fuel sender.
Old Aug 17, 2016 | 10:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, one thing you need to be aware of, a lot of the aftermarket fuel sending units have a 5/16" fuel pick up, the original was 3/8".
Old Aug 17, 2016 | 10:47 PM
HIO Silver's Avatar
HIO Silver
Street cred helps if you visit an auto parts store.
... ask for a mechanical fuel pump and the hand you a mechanical fuel pump.
... ask for a manual pump and they'll give you directions to Home Depot.
ken kirkland
1997 - 2003 F150
Mar 21, 2019 07:21 AM
1972fordhighboy2
Sep 15, 2018 05:57 PM
arse_sidewards
Sep 28, 2016 06:29 PM
luvmytruck460
Sep 14, 2006 07:32 AM
rodbeed
Jan 15, 2004 08:59 AM
