Sponsored by: Auxito
inline fuel pump
Old Mar 20, 2019 | 03:11 PM
ken kirkland's Avatar
ken kirkland
inline fuel pump
Anyone tried running an inline fuel pump in there f150 with 5.0 efi?if so what type and model i feel a little uneasy about putting how wires in my fuel tank like stock fuel pumps are.
Old Mar 20, 2019 | 05:49 PM
enriched&beyound's Avatar
enriched&beyound
I understand your concern....but... they have been putting fuel pumps and sending units in tanks for sometime now with little to no problems. Other than it harder to change.
I'm sure it can be done, but you might have rewire the gauge so that it would still work & those wires would still be in the tank. Also you would probably have to open the tank up and remove the old pump and install a hose to the pickup sock. So the old pump wouldn't create too much restriction. Granted the sending unit that registers how full/empty the tank is doesn't require as much power as the OEM pump, but still there is still power there.
If your wires are getting hot/ warming up going to your current fuel pump in the factory location then I'd say you have a problem with the pump or wiring going to it.
Old Mar 20, 2019 | 06:32 PM
steve(ill)'s Avatar
steve(ill)
The float / fuel level controller works electrically also... Been inside the tank FOREVER... I had a 1989 F250 with fuel pump in the tank... that was 30 years ago.
Old Mar 21, 2019 | 12:56 AM
Bluegrass 7's Avatar
Bluegrass 7
1985 had out board inline fuel pump mounted on the frame.
Old Mar 21, 2019 | 07:21 AM
Sam I Am's Avatar
Sam I Am
I'm still waiting on pics of this 5.0 Lobo
James Rutley
Aerostar
Jun 11, 2011 11:33 AM
cookkd
Aerostar
Jun 27, 2009 04:13 PM
grndlzrd
Jun 11, 2007 06:30 AM
tony b
Nov 4, 2006 10:10 AM
moose94
33
Jun 30, 2005 12:03 AM
