Electrical problem
Old Aug 13, 2016 | 12:01 PM
Jimbo757's Avatar
Jimbo757
Electrical problem
While changing out a light bulb in a door panel I had to use pliers ( bulb was broken ) I knew I would blow a fuse but it has taken out the dash board, power windows and even the radio I have checked the CB 601 and that's fine any ideas what to look for next ?
Old Aug 13, 2016 | 01:47 PM
agsmv1's Avatar
agsmv1
Not knowing what year...I think 41 instrument cluster would be a good start...not sure why but 35 is also listed as instrument cluster.
Old Aug 13, 2016 | 01:50 PM
Jimbo757's Avatar
Jimbo757
It's an 02
Old Aug 13, 2016 | 08:56 PM
agsmv1's Avatar
agsmv1
For some reason when the lights in my running board burnt to a crisp, it took out the same elements...I think it was 17..Those should be good numbers...
Old Aug 14, 2016 | 06:02 AM
Jimbo757's Avatar
Jimbo757
Thanks, running board lights are out also and your right it is # 17 for them but that's not the problem, it seem to be whatever relay,circuit breaker or fuse that feeds those circuits all fuses in the panel ate good !
Old Aug 14, 2016 | 07:05 AM
projectSHO89's Avatar
projectSHO89
Fuse F41 feeds all those lights via a relay in the instrument cluster.
Old Aug 14, 2016 | 07:32 AM
Jimbo757's Avatar
Jimbo757
Thanks all found it it was the instrument cluster fuse, had to check it with a meter couldn't tell it was bad by looking, can't belie all it took out running board lights, radio, courtesy lights,instrument cluster and power windows wow !
Old Aug 14, 2016 | 08:23 AM
projectSHO89
Makes perfect sense in light of my previous post. If the cluster is not powered, the relay cannot be energized and the lights cannot work.
What doesn't make sense is how a short circuit in the lighting string can take out the fuse for the cluster.
Old Aug 14, 2016 | 08:29 AM
Jimbo757's Avatar
Jimbo757
Tell me about it that's why I went thru it fuse by fuse on all affected systems never would have thought a 10 amp fuse could affect so much !
muecker
2009 - 2014 F150
Apr 29, 2025 03:14 PM
ranger719
Feb 1, 2016 05:43 PM
Wicked Endings
May 8, 2010 10:46 PM
abvoitik
May 29, 2007 10:37 PM
Jay Fletcher
Apr 29, 2003 12:00 PM
