Electrical problem
Electrical problem
While changing out a light bulb in a door panel I had to use pliers ( bulb was broken ) I knew I would blow a fuse but it has taken out the dash board, power windows and even the radio I have checked the CB 601 and that's fine any ideas what to look for next ?
Thanks, running board lights are out also and your right it is # 17 for them but that's not the problem, it seem to be whatever relay,circuit breaker or fuse that feeds those circuits all fuses in the panel ate good !
Thanks all found it it was the instrument cluster fuse, had to check it with a meter couldn't tell it was bad by looking, can't belie all it took out running board lights, radio, courtesy lights,instrument cluster and power windows wow !
Makes perfect sense in light of my previous post. If the cluster is not powered, the relay cannot be energized and the lights cannot work.
What doesn't make sense is how a short circuit in the lighting string can take out the fuse for the cluster.
Wicked Endings
May 8, 2010 10:46 PM
Jay Fletcher
Apr 29, 2003 12:00 PM
