banjo bolts
Old Aug 12, 2016 | 09:11 AM
duck fan's Avatar
duck fan
Because racetruck
Originally Posted by fordpride
If you want hi flow drill out the stock ones. What do you think they are doing ?
Really bad idea to drill the stockers, they are just pot metal and many break on install. Best idea is leave it stock or use an aftermarket that has been specifically machined from different material and ported for least turbulent flow.
Old Aug 12, 2016 | 09:13 AM
444dieselrod's Avatar
444dieselrod
Huh, I stand corrected, now I'm gunna have to go look at one of the spare motors.
Why not just remove them and use an NTP to ORB fitting in the front of the motor and reverse the fuel flow. I don't see why you would need the high flows after the injectors.
Old Aug 12, 2016 | 09:31 AM
Ezalycasaid's Avatar
They advertise the stock banjo bolts as " The last points of restriction in our fuel systems". From the small amount of info I could find on these, it just seems like a way to make money for them. Unless u plug one or your making 500hp plus and running a quadzilla hpop. It's just super overkill.
Old Aug 12, 2016 | 11:05 AM
cowmilker08's Avatar
cowmilker08
Only reason I can dream up is so that your FPR doesn't see a lower pressure than the injectors (and other upstream components) due to the restriction of the banjo bolt.
Old Aug 12, 2016 | 06:21 PM
fordman67's Avatar
fordman67
high flow pump at idle could create to much pressure before the outlet banjo and thus not let the regulator control fuel pressure at idle.
Old Aug 12, 2016 | 07:36 PM
fordpride's Avatar
fordpride
I've now done it on 6 engines and not one failure. Like I said though unless you are making butt tons of power you won't notice any difference.
Restoman2
Mar 18, 2011 12:40 PM
gbroehl1
Connecticut Chapter
Oct 15, 2009 05:27 PM
Martys82
Jan 11, 2003 02:49 PM
jopey
Oct 17, 2002 07:16 PM
