banjo bolts
Old Aug 10, 2016 | 11:38 PM
Ezalycasaid's Avatar
Ezalycasaid
banjo bolts
Is it worth swapping out the banjo bolts on our trucks with the high flow style? Has anyone here ever done it with bellowed up pipes? Also how hard is it to get to the rear ones, do u have to take the up pipes off? Thanks guys.
Old Aug 11, 2016 | 04:20 AM
97-psd's Avatar
97-psd
I am uncertain as to what you are referring to when you say high flow banjo bolts. The only banjo bolts that come to mind is the one going to the fuel pump. Although it is early, so I may not be remembering well yet.
Old Aug 11, 2016 | 06:38 AM
fordpride's Avatar
fordpride
IMO it's not worth it unless they are giving you a issue or you're making 500+hp
Old Aug 11, 2016 | 09:24 AM
Ezalycasaid
Ur thinking of the large banjo bolt that manifolds the fuel lines to the back of the engine. There are 4 more banjo bolts that are in the very back and front of the engine. The ones in the front seem easy to get to. The ones in the rear seem like a nightmare.
Old Aug 11, 2016 | 09:25 AM
Ezalycasaid
Ok thanks. So not worth it with 90cc injectors. Haha.
Old Aug 11, 2016 | 10:38 AM
444dieselrod's Avatar
444dieselrod
Umm, no.... The just 1/4 pipe thread with a 90* fitting that's adapted to a flared hose fitting. There a pain to get to but nothing special.
Old Aug 11, 2016 | 12:28 PM
fordpride's Avatar
fordpride
Rod he's talking about the fuel rail plugs
Old Aug 11, 2016 | 12:30 PM
fordpride's Avatar
fordpride
Old Aug 11, 2016 | 12:40 PM
Jarrett Campbell's Avatar
Jarrett Campbell
On Strictly Diesel's website, they recommend the high flow banjo bolt to be used with their complete OBS E fuel kit. I think it is a typo.
Old Aug 11, 2016 | 12:43 PM
fordpride's Avatar
fordpride
If you want hi flow drill out the stock ones. What do you think they are doing ?
Old Aug 11, 2016 | 12:52 PM
fordman67's Avatar
fordman67
I plan on a set before I hit the rollers to destroy an auto lol
Old Aug 11, 2016 | 01:27 PM
fordman67's Avatar
fordman67
They use copper washers instead of orings as well.
And they are a bit nicer than just hogging out stockers.
Old Aug 11, 2016 | 09:56 PM
Ezalycasaid
Here are the size of the ones I'm talking about. I ordered 2 before I knew u need 4. Just incase I did need them when the kit got here. 1 of them goes on the pass and driver side fuel rail in both the back and front, so 2 in the front 2 in the back. They're located right above the freeze plugs on the front and back.Lol anyone need 2 for cheap?
Old Aug 11, 2016 | 10:01 PM
z31freakify's Avatar
z31freakify
Ive read and heard good thing about those style of banjo bolts on the 6.doh's but you hardly hear them on the 7.3 scene.
Old Aug 12, 2016 | 06:41 AM
lee00's Avatar
lee00
I have put Riffraff's version in mine...both front and back...engine was out when I did it...I think 2 of the 4 were leaking though...
