Quarter Panel Window Help!
Old Aug 4, 2016 | 06:47 PM
AlexSaldana's Avatar
AlexSaldana
I've had my Ex for 3 years now and have never been able to get the rear windows to open. I recently found out I was missing the fuse for them but as soon as I put in one and tried to open a window it blew. Anyone know why or how to fix it?
Old Aug 4, 2016 | 08:29 PM
Jeff53's Avatar
Jeff53
Now you know why the fuse was missing.
Did you try both windows or just one? If just one, I'd try putting another fuse in and trying the opposite window. If it opens, then there could be a short in the one circuit or a problem with the motor.
Old Aug 5, 2016 | 04:27 PM
AlexSaldana
I popped another fuse in and tried the left window and it worked without a problem but if i try the right one it blows it out
Old Aug 5, 2016 | 05:33 PM
seijirou's Avatar
seijirou
Either the wiring between the switch and the motor is shorted to ground, or the motor itself is bad. Start by unplugging the motor and then testing. If it still blows it's the wires, if not there's a good chance it's the motor.
Old Aug 5, 2016 | 10:09 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
I had this issue at first, turns out the motor was jammed up. I had a friend tap it with a screwdriver while I pressed the switch and it finally started working and quit blowing fuses. It'll still jam up now and then and a tap sets it free. No fuses blown since. I also sprayed some lithium grease in the hinge areas.
Not saying it's YOUR fix, but it's a possibility.
Old Aug 9, 2016 | 11:02 AM
kruc's Avatar
kruc
My drivers side quit working about a month ago, but I haven't got to dive into it yet. It's not blowing any fuses, and I can still hear it clicking when I press the switch, it just doesn't actually open the window. Any ideas?
svt2205
2009 - 2014 F150
21
Sep 19, 2014 04:07 AM
xmontex4
Nov 14, 2011 07:14 PM
ron's power stroke
Jun 28, 2008 09:53 PM
tyler9mm
2004 - 2008 F150
Aug 1, 2007 03:11 AM
Jeepjones85
1997 - 2003 F150
Jun 15, 2007 01:58 AM
