Sponsored by: Real Truck
Automatic window almost wont close or open
Old Oct 11, 2011 | 09:30 AM
xmontex4's Avatar
xmontex4
My passenger side window will move like normal until it gets to the bottom half of the opening then it sounds like the motor is working extra hard to pull it the rest of the way down. This only happens in the lower half of the opening so the same thing happens when its going up. The whole assembly inside the door has been changed twice, it was changed again because it was under warranty and we thought it was the assembly. After changing it it worked better periodicly but no its back to its old ways. could it be wiring or a fuse? in the winter sometimes it almost doesnt make it all the way up. Anything you guys know about this would be great. Thanks in advance!
Old Nov 14, 2011 | 02:49 PM
xmontex4's Avatar
xmontex4
BUMP, does anyone have any ideas how to fix this? basically my window slows down at about half way going either up or down and in the winter it somtimes barley goes up, the motor and everything has been replaced twice with no luck.
Old Nov 14, 2011 | 03:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It can't be a fuse. Fuses work or they don't. If the fuse was bad the window won't work at all.
When you say everything has been replaced, does that mean the regulator? If so, lubing the window tracks with a silicone spray might help it.
Old Nov 14, 2011 | 03:56 PM
xmontex4's Avatar
xmontex4
I believe so everything has been replaced except it the window, so I can try that I guess
Old Nov 14, 2011 | 05:28 PM
powerstroke72's Avatar
powerstroke72
I fixed your thread title to say "window" instead of "mirror".
Old Nov 14, 2011 | 05:32 PM
BigAlsPSD's Avatar
BigAlsPSD
I have been using the silicone lubricant you can get for lubing of water faucets to grease the track and keep things smooth, check out this thread
https://www.ford-trucks.com/forums/4...luggish+window
Old Nov 14, 2011 | 06:27 PM
xmontex4's Avatar
xmontex4
Thanks lol I figured that was why people weren't answering lol
Old Nov 14, 2011 | 06:30 PM
xmontex4's Avatar
xmontex4
Awsome, thanks for the link, ill give this a try this weekend and post how it turns out!
Old Nov 14, 2011 | 06:47 PM
PA-Mark's Avatar
PA-Mark
hope this helps
A few years ago I helped one buddy of mine out before with an F150 that had a similar window problem. I know it my not be exactly the same set up but its got to be close...
So the cables inside the the door that do the work of the window motor, slipped off the pivot wheels and started to frey from the added friction, and started acting up as your is. by the time I got to it the window would not move at all. The freyed cable was so bad it would no longer travel through the cable housing. In your case, you say everything was replaced, but I could see a service writer ordering a motor and switch with wireing.... but i can imagine they may overlook these cable pulleys. Its worth a shot to check out.
P.S. Like I said im not even sure these doors are set up the same, but if they are its worth a try... Hope this helps, Mark
Old Nov 14, 2011 | 06:58 PM
xmontex4's Avatar
xmontex4
Any knowledge is much appreciated, im only 18 so I don't have access to alot of tools that would be handy but you im always looking for ways to fix things so one day Ill be able to save a few $$$.
Old Nov 14, 2011 | 07:03 PM
PA-Mark's Avatar
PA-Mark
Well taking off the door requires few tools, mostly common tools. just pay attention to how it comes apart, and get in there and look around. peeling off the plastic behind the door panel my require some glue to put back down, but not usually... before you take it apart, secure some lube as described previously, lube it anyway since its apart. Good luck
Old Nov 14, 2011 | 07:14 PM
xmontex4's Avatar
xmontex4
Yeah I just got the panel poping tool which makes it easier and this door ppanel is broken anyway lol alt of hooks are broken from when they replaced the motor..I never noticed but its pretty no big deal.
7.3RP
1978 - 1996 Big Bronco
May 11, 2015 11:09 PM
svt2205
2009 - 2014 F150
21
Sep 19, 2014 04:07 AM
gyrospinup
1997 - 2003 F150
Sep 16, 2011 09:43 PM
Jeepjones85
1997 - 2003 F150
Jun 15, 2007 01:58 AM
rschleicher
Escape & Escape Hybrid
Jan 9, 2007 05:28 AM
