The headliner on my '96 single cab has finally started to sag. Does anyone have any tips on how to remove & repair? It isn't so bad right now, but when it gets humid out it tends to sag more, so I'd just like to attack this now and be done with it. Thanks in advance for any input!
I did one on an F150 I sold a few months ago. I went to a headliner supply shop here in town and bought the material for like $35. Then I bought a can of 3M Headliner Adhesive Spray. The hardest part is getting the old foam off the headliner board. A trick I found is to spray it with brake cleaner in about a 1' x 1' section and then scrape it off with a large putty knife.
I have a SCAB, I believe that to remove the headliner board without bending it the seats need to be removed first.
I want to say that I saw a post on here where a member with a SCAB actually did it without removing the seats and although he had to bend the board to remove/reinstall, you could not tell after it was all back in place.
Anyone that has done this on a Supercab chime in. I need to do mine at some point
Mine was a SuperCab and I did not remove the seats. The truck had a bench seat if that matters. I did have to bend the board a little to get it thru the door opening.
Simple job. Remove trim and screws holding it up, then remove from vehicle. I scraped the foam off, hit it with a sander to get it all, and wiped it clean. JoAnne Fabric had a bolt of the same color foam backed velour that came from the factory for about $20. I also picked up a can of 3M spray adhesive.
Spray the glue, lay material on the base, press and stretch to fit, and let dry. Next day, use a razor knife to trim, and re-install. Easiest update possible...
I've done this on a '95 years ago. I gently pulled the old material off and then used Isopropol alchohol to break down the adhesive, and scraped off the mushy adhesive with a putty knife, but can also use a single blade razor blade. Let it dry really good overnight and use the better 3M adhesive spray to install new material. At the time, I bought the material from one of the car parts chains, but don't know if they would still carry the stuff.
