Dentside bed comparability...
Old Jul 26, 2016 | 11:42 AM
Anthony487's Avatar
Anthony487
This is probably a stupid question but I've never had a problem swapping beds but someone I was talking to did..
If I am correct, 73-79 f150-350 2x4 or 4x4, custom to lariat all have the same 2 beds. Either a 6ft or an 8ft. Exact same from truck to truck as long as. Is the correct length for the truck. Is this true?
Old Jul 26, 2016 | 11:49 AM
mikeo0o0o0's Avatar
mikeo0o0o0
No. The 73-76 Styleside have exposed fuel fillers the 77-79 have the fuel filler concealed behind a door.
The 73-77.5 F250 4WD have narrow frames so the attaching bolts are closer together.
The 73-79 2WD and the 77.5-79 F250 4WD have wide frames.
Then you also have the 73-79 SUPER camper special with the 140" wheelbase which is a whole different animal.
Not to mention the short and long wheelbase Flareside.
Old Jul 26, 2016 | 12:02 PM
Anthony487's Avatar
Anthony487
Wow, alright. Thank you for clearing that up!
Old Jul 26, 2016 | 12:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
To put a older bed 73-77.5 F250 4WD (with the narrower bolt holes) on a newer wider frame and not have to drill new holes, weld tabs on the frame.
And vice versa if you are putting a newer bed on an older high boy frame.
Old Jul 26, 2016 | 02:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
33 1/2" width between the inner frame rails behind the cab: 1961/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79 F350's on the 140" wheelbase & Cab & Chassis.
37 1/2" width between the inner frame rails behind the cab: 1973/79 F100 & F350 except as noted above / 1973/79 F250 2WD / 1975/79 F150 / 1978/79 F250 4WD / 1979 F350 4WD
sam_stach
Oct 17, 2015 10:30 PM
red450ih
Mar 8, 2015 04:33 PM
justafordman
Jan 3, 2015 04:54 PM
headleyj
Feb 9, 2007 06:32 AM
smaynor
Mar 5, 2003 05:39 PM
