Oil viscosity
Old Jul 20, 2016 | 02:08 PM
Marioj87's Avatar
Marioj87
Oil viscosity
I have a 2006 f150 fx4.
I'm using 5w20 just like the service manual says to use, but I'm wondering what were to happen if I were to use 5w30 oil instead? I went to the auto part store and the recommended upgrading to 5w30 since I have 100,000k plus on true truck.
Thanks for reading.
Old Jul 20, 2016 | 02:19 PM
Tedster9's Avatar
Tedster9
Remember oil viscosities have been trending downward, in part, to eke out that last 300 yards in extra fuel economy. With that said I don't think the differences in those weights will make much difference. Keep clean, fresh oil in it and quality filters and fuggedaboutit.
Old Jul 20, 2016 | 04:30 PM
F150Torqued's Avatar
F150Torqued
I agree with @Tedster9 . And he expressed it with class. "Keep clean, fresh oil in it and quality filters and fuggedaboutit".
I switched to 5W30 on my '04 5.4L after the timing job @ 212k miles. Before that, I even tried 0w40 for a while. With that, there was a 'hard to observe' slight difference in the VCT response to the PCM's retard commands (as observed on scanner monitor gauges). I think that is a result of getting the slightly thicker oil through the fine screens in the VCT Solenoids into the Phasers. But it is was enough to set a DTC code. But 5w30 is doing fine down here in South Texas.
Old Jul 20, 2016 | 05:08 PM
steve(ill)'s Avatar
steve(ill)
Mario, there should be no difference. Since you are in Texas, consider the same truck in Minnesota.........With your high temps, 5W30 might be a good move.
Old Jul 20, 2016 | 05:41 PM
Marioj87's Avatar
Marioj87
Thank you guys.
Old Jul 20, 2016 | 09:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I have an '07 5.4 3V. It now has 208,000+ miles on it. I've been running 5W30 conventional oil ever since it was out of warranty. Change the oil and filter every 3000 miles.
Florida, with the 95+ degree temps, quite often topping 100 (don't believe the tourism commercials, it gets HOT here) I don't like the idea of 5W20.
So far I have had no problems with the engine. It still runs and idles smooth and gets decent mileage.
Old Jul 21, 2016 | 11:42 AM
EBC-150's Avatar
EBC-150
Much debated topic across the F-150 forums...You'll find 'absolutists' that state you can ONLY use 5w20, while the manual calls for a heavier weight in warmer climates, also the Australian 5.4 spec's at a heavier weight oil. I've read information suggesting that Ford uses the 5w20 to get the most MPG's, at the expense of longevity. As important as pressure is on these modular's top-ends, I use 5w30 on an engine that's notorious for leaking past the tensioners and blowing out the back side of the (stock) oil pump at RPM's.
Old Jul 22, 2016 | 06:36 PM
Marioj87's Avatar
Marioj87
Do still use 7quarts or move down to 6quarts?
Old Jul 22, 2016 | 08:11 PM
F150Torqued
Seven qts.
Old Sep 15, 2016 | 10:41 PM
BII Plow Truck's Avatar
BII Plow Truck
Originally Posted by mikeo0o0o0
........I don't like the idea of 5W20.
Not a worry if you use a full synthetic. Cheaper after 208,000 miles too.....6k oil changes vs 3k oil changes saves you $$$$$$$......do the math.
Old Sep 16, 2016 | 12:18 AM
77 1/2 F250's Avatar
77 1/2 F250
Seems like most of these questions a for the 5.4 and maybe the 4.6 V8's. What about for those of us with the pushrod 4.2 V6?
Robert
Old Oct 1, 2016 | 07:36 PM
renegade734's Avatar
renegade734
I have 7000 reasons why not to run 5w30. That was the cost for the crate motor. I am now a firm believer in using what the manual calls for.
Old Oct 4, 2016 | 05:52 PM
steve(ill)'s Avatar
steve(ill)
you will need some proof to say that. Lot of people run 5w30 in the motor and no problems.
Old Oct 5, 2016 | 10:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The ol' girl now has 213,000+ miles on her and still running fine. Cam covers have never been off, quiet and smooth.
Even if I went with full synthetic, I would still change the oil more often than required, so the savings wouldn't be as significant (I'm stubborn when it comes to oil change mileage).
Old Oct 7, 2016 | 02:33 PM
tbear853's Avatar
tbear853
I too started using 5W30 in my 5.4 and 4.6 motors some time back after I used up the last of my 5W20. Still use MC filters.
