7.3 sputters after TS chip and removal
Old 07-16-2016, 06:51 PM
fordguy390's Avatar
fordguy390
fordguy390 is offline
I just put a TS 6 pos. chip in my 95 f250 ran good only had a few tuning problems with tranny shift points. on my way home last night in 75 hp tune i noticed a lope idle and chuggs at 900 to 1200 rpm and when i get on the gas the truck runs like crap and pops. sounds like the 6.0 pop, pop. so i took the chip off and still have the problem. the truck has 162 k miles and oil change every 3 k and fuel additive with fill ups so idk about injectors being bad. replaced ipr, valvecover gaskets and wires 2 months ago. fuel press 65 idle. no codes. waiting on cylinder contribution test. i have extra cps laying around ill try but was wondering if anyone had this problem before and what it was. ill try to upload a vid of the pop sounds and chuggs. THanks
Old 07-16-2016, 07:04 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,189 Likes on 817 Posts
Check the IPR tinner man nut it might of fell of.
Old 07-16-2016, 07:05 PM
fordpride's Avatar
fordpride
fordpride is offline
Sounds like the increased oil pressure may have took out some injector orings.
Have you ever changed the injector orings ?
Old 07-16-2016, 07:25 PM
fordguy390's Avatar
fordguy390
I haven't changed the O rings. Thats what I was thinking also. Im putting the gray CPS in now and seeing if it makes a difference. whats a good brand for o rings? im about to do a contribution test and if that fails ill go from there
Old 07-16-2016, 07:45 PM
z31freakify
Alliant is should be your only choice.
Old 07-16-2016, 08:00 PM
fordguy390's Avatar
fordguy390
I looked online and what not but does anyone know a good form or video on how test for bad orings. I heard oil in your fuel bowl? 7.3 are dead heads. and If one leaks wont it lower the oil pressure for the whole rail? any good ways to test
Old 07-16-2016, 08:03 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Check your filter. If it's black the orings are due
Old 07-16-2016, 08:08 PM
fordpride's Avatar
fordpride
Running better when cold is one.
With engine warm and in Park or N mash the go pedal to the floor. If it revs to 15-1800 rpm then sputters for a second or two then climbs to 3k rpm that's bad orings
Old 07-16-2016, 08:23 PM
fordguy390's Avatar
fordguy390
this is the vid of what it does. And it slightly stutters when i mash the pedal in park. when i stall it to 900 -1200 rpm it shakes badly
Old 07-16-2016, 08:32 PM
fordpride's Avatar
fordpride
That sounds like a dead hole. I'd start looking at uvch
Old 07-16-2016, 08:39 PM
fordguy390's Avatar
fordguy390
I would think that too but i just replaced a month or so ago. pigtails and all. I checked the wiring it all looked good. wouldnt hurt to pop the covers off and look
carter g
20
07-29-2016 06:46 AM
DougJ_1997PSD
32
12-08-2015 06:38 PM
rlozer
53
11-14-2014 04:41 AM
Diesel cat
04-01-2012 10:26 PM
toddncandy
06-10-2006 10:04 AM
Quick Reply: 7.3 sputters after TS chip and removal
